Old 04-17-2007, 02:56 AM   #1
swied
swied's Avatar
swied is on a distinguished road
Default rpm wont go past 4
Hey guys, my buddy and I just got my 88 Supra Turbo running and moving!!! We took it out and the only problem is that once it hits 4,000 rpm it wont go no more and really bogs down, spits and sputters. What should we try and what should we fix?
swied is offline   Reply With Quote
Old 04-17-2007, 01:48 PM   #2
IHateHacks
IHateHacks's Avatar
Ok I saw your no start post and now this one. This has happened to me once before on an 85 Monte carlo SS years ago. I had just got done putting headers on it, but forgot to tighten the nut holding the wire on the starter, car would start but only rev to 3k rpm.
Try tightening the cable that is held on by the 12mm nut on your starter and make sure the little clip connector wire is on the starter tight.
Old 04-18-2007, 01:17 AM   #3
ddmcse
ddmcse's Avatar
Cool
massive boost leak
prolly blow off one of the hoses on the accordian type 4 inch hose on the intake
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-08-2007, 02:04 AM   #4
White87Turbo
White87Turbo is on a distinguished road
I agree its either a massive boost leak or you have a broken wire from one of your knock sensors.
White87Turbo is offline   Reply With Quote
Old 05-08-2007, 04:34 PM   #5
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
again, i have had this prob. b4 and it could also be the TPS.
Supra_87_mk3 is offline   Reply With Quote
Problem: Won't past 3K RPM. Any help? TTPrince MKIII Supra 1 05-22-2008 04:14 PM
wont go past 3000 rpms mk3ben.com MKIII Supra 6 09-22-2007 07:52 PM
rev not past 4k swied MKIII Supra 1 04-27-2007 04:40 AM
rpm don't go past 3500-4000 range Kou Vang MKIII Supra 10 09-16-2006 09:08 AM
