Old 01-30-2007, 02:40 AM   #1
Caliturbo88
Caliturbo88 is on a distinguished road
Default # 5 cylinder DEAD!???
Well on the 86 i got, number 5 cylinder just died off one night driving home. Its a NA motor. We had all the injectors professionaly flowed and new spark plugs and wires(its getting spark and fuel). What would cause the cylinder to loose compression? i can tell its not getting nearly enough compression on number 5 because when you crank the starter, it raises and lowers rpm as it tries to turn over. Could it possibly be something besides worn rings or not sealing valves?
Caliturbo88 is offline   Reply With Quote
Old 01-30-2007, 04:59 PM   #2
mattfurlani
mattfurlani is on a distinguished road
The raising and lowering RPM isn't a sign that the cylinder is dead. you need to do more testing before you can make that hypothesis
86.5 NA has 156 cranking PSI that's not what it runs at. Looking up the running PSI and the percent tolerance between one cylinder and the others will determine whether or not its bad. Losing compression can only be caused by a busted, burnt, or craked valve, worn rings, a hole in the cylinder itself. or the lack of the breathability of the cylinder. since you have fuel spark and air i'd do a cylidner leakage test.
Its broke, it could be anything, and cost of repairs will greatly exceed the value of the car
mattfurlani is offline   Reply With Quote
Old 01-30-2007, 09:58 PM   #3
Caliturbo88
what size/thread pitch compression tester do i need?
Old 01-30-2007, 11:21 PM   #4
mattfurlani
i don't remember. you can look it up online or try and find a manual or a factory manual. Its probably a smaller size.
ASk some of these other guys i'm sure they've done it a million times.
Old 01-31-2007, 03:49 AM   #5
mrnickleye
mrnickleye's Avatar
Same size as the spark plug threads. I believe its 14mm. most compression gauges will have threads for both size spark plug holes. The gauge is a cheap tool, and everyone who works on his car should have one in his toolbox.
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
HELP AGAIN!! 94 twin turbo...good ignitor..no fire on one cylinder!! suprarx7m3 MKIV Supra 4 11-02-2007 11:12 AM
ignition lock cylinder suprabahamut Non-Generation Specific Questions 2 05-04-2007 03:29 PM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
