Old 03-24-2007, 05:22 PM   #11
Bill UK
AEM EMS
Bill UK's Avatar
One possible cause could be that you have no impellor blades on your water pump! As I found out on one of my supras which previously had a few BHG `s The coolant becomes acidic/corrosive when mixed with combustion gases and etches away the impellor blades. The cost of new Toyota water pump is about $200 but you can get a new Aftermarket pump for $70 . Many supra owners in the UK use this company https://www.sapmotorparts.com but you should be able to find one similar in US. Below is a pic of a Toyota pump and an aftermarket one, as you can see the Toyota one has thin pressed-steel blades and the aftermarket one has thicker cast blades.
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
random pics of random things... dannydavi Off Topic Forum 3 06-11-2007 07:13 AM
Need Help, Overheating Problems MDellboy420 MKIII Supra 9 12-19-2005 06:46 AM
