Old 01-08-2007, 01:46 PM   #1
unkymurch
unkymurch is on a distinguished road
Default Thanks for the replies, What about cleaning lenses?
I finally got at it and managed to remove the tail lights after practically gutting the interior to remove the panels. The seals were falling apart. I'll check with the dealer on replacements. If I can't find them, I'll consider making my own. I'll also crawl under the car and look for drain plugs.
The tail light lenses have some slimmy algae/scum inside from the water. It appears as black spots that can be seen from the outside. The clear/white fresnel lenses have deposits that make the lense look cloudy and dirty. Any suggestions/ideas on cleaning them out and making them clear again?
unkymurch is offline   Reply With Quote
Old 01-09-2007, 02:25 AM   #2
mrnickleye
mrnickleye's Avatar
There is some stuff at my local Carquest store that makes those cloudy plastic headlight lenses look new again. That may work for your problem. I've seen 2 headlights done, and they did look new again.
Its a kit, in a plastic/metallic sealed bag, kinda blue and silver.
Old 03-02-2007, 12:59 AM   #3
unkymurch
Thanks for all the input. I replaced the tail light gaskets which I got new from the Toyota dealer for about $35 for the pair. (Always mention Supra Club to get a discounted price.) Since it was so much trouble to get the tail lights off and so the gaskets would last longer than expected, I got some 50 year silicon rubber and completely coated every surface of the new rubber gaskets. Now if the car falls apart, the tail light gaskets will look new.
As far as the algae and slime in the tail lights, I soaked and flushed both of them in a bleach and dish detergent solution for about two straight days. It took some trickly maneuvering since the algae/slime was trapped in the tight crevices of the lense assembly. I finally got all of it all out and then used a hair dryer to dry them out thoroughly.
Supra space saver wheel question aquanuke Non-Generation Specific Questions 0 03-25-2008 10:24 PM
Rusty Rear Wheel Arches Bill UK Non-Generation Specific Questions 1 01-21-2007 10:07 PM
Supra rear ends Gmrwizard Non-Generation Specific Questions 0 02-22-2006 02:03 PM
