Old 12-04-2006, 12:02 AM   #1
MRice
MRice is on a distinguished road
Question Question!
I'm parking my 1987 toyota supra for the winter for the many obvious reason, I have a car cover to cover it up and some spray on oil stuff to lube everything up while its parked but.... Here's my question since it's outside in -30ish CELCIUS weather what should I do? And I mean everything I need to do? like should I start it up somtimes and should I put anything additives in the gas? And what about rust anything to prevent? This car is MINT any information would BE AWESOME!
Cheers mates
Mitch Rice
MRice is offline   Reply With Quote
Old 12-04-2006, 12:33 AM   #2
burton51m
burton51m's Avatar
you dont really need to do anything...just let it run every once in a while
Old 12-04-2006, 05:53 AM   #3
sportriderseattle
sportriderseattle's Avatar
sportriderseattle is on a distinguished road
If your car's a Turbo you should start it once a week or every other week at worse. If your cars an n/a, you "should" be okay for once a month. With a turbo you have to keep things moving or the seals start to dry out and your car will smoke when you start her over again.
Dan
http://www.cardomain.com/ride/2200872
1987 Toyota Supra Turbo Targa, 5 speed, Light blue, 67K miles, MKIV TT polished wheels
sportriderseattle is offline   Reply With Quote
Old 12-04-2006, 09:00 PM   #4
jeepkaiser65
jeepkaiser65 is on a distinguished road
put it on jack stands
Id rather die on my feet then live on my knees
jeepkaiser65 is offline   Reply With Quote
Old 12-04-2006, 09:23 PM   #5
tone loc
tone loc's Avatar
i dont understand what that does?
i heard it before and they told so your tires dont get like a lump in them.
Old 12-05-2006, 02:21 AM   #6
mrnickleye
mrnickleye's Avatar
Thumbs up Good idea
The steel belts in the tires can take on a "set"(flat spot), and then when you start driving it again, you will get a belt seperation. Been there, done that ! Many motor homes and trailers get this from sitting too long.
If you drive the car once a week, it should not happen, as you will park in a different place on the tires.
Plus running it on stands, or once a week drive, the oils in the diff, tranny, p/s, and engine will get spread around and keep moisure from rusting and corroding things.
Old 12-05-2006, 01:07 PM   #7
SupraDupra
SupraDupra's Avatar
I would also dump a bottle of fuel stabilizer in the tank so your gas doesn't get too funky.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
