Old 11-25-2006, 03:49 AM   #1
Supra2NR
Supra2NR's Avatar
Default car died
ok here's the deal i just got of the e way and as soon as i put it in neutral
the car died on me
i was pushing 80 and tht was it
now im stuck in a parking garage illegally
and the car wont start
im using my friends computer to type this
anybody got any idea whats causing this
and p.s. everytime i try to start the car
smoke billows out of the turbo
help asap
--pat
Old 11-25-2006, 12:13 PM   #2
SupraDupra
SupraDupra's Avatar
It doesn't sound pretty whatever it is.You should have it towed home before it gets taken to a impound.I doubt your gunna get it going again without some wrench time.Sorry about your luck
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 11-25-2006, 04:54 PM   #3
Supra2NR
Supra2NR's Avatar
it workd after it cooled down and it happend again on my way home
the car shuts down everytime it heats up
there's two places that the smoke is coming from
underneath the turbo
and in front of the engine right by where the fan is
car has a high idle of 1500 rpms
Old 11-25-2006, 05:16 PM   #4
SupraDupra
SupraDupra's Avatar
I had an engine spin a bearing once ,and it would only run when it was cool.Apparently the heat expansion would lock the engine up.Mabey you are getting something similar in your turbo.As with anything turbo related from me ,that's just a guess.
1974 'Cuda - 318
2001 Cherokee
Old 11-25-2006, 05:33 PM   #5
redmaro
I've had similar problems to where my car would only start when it was cool and it would shut off when it heated up. The problem was caused by distributor(coil).
MK3, Auto, Turbo.
Old 11-25-2006, 06:15 PM   #6
Supra2NR
Supra2NR's Avatar
yea but when u had the problem, did it include smoke coming out from under the turbo?
Old 11-26-2006, 05:02 AM   #7
redmaro
Nope, no smoke under the turbo.
MK3, Auto, Turbo.
Old 11-26-2006, 10:45 AM   #8
Supra2NR
Supra2NR's Avatar
right now, im trying to work out the code issues out
then, ill get to the turbo
now i see why he gave me a repair manual with the car
cuz i would be using it pretty soon
Old 11-26-2006, 05:16 PM   #9
SYKOKIDD
SYKOKIDD is on a distinguished road
Unhappy Cuttoff When Warmed Up.
YES MY 1987 SUPRA TURBO SAT FOR 1YEAR, IT STARTED UP AND CUTTOFF ON ITS OWN, I THOUGHT MAYBE OVERHEATING I CHANGED THE THERMOSTAT AND POWER MANAGEMENT RELAY, NO CHANGE WHEN IT WARMED UP IT CUTTOFF , UNTIL IT COOLED DOWN, DEALER CHANGED THE FUEL PUMP , NO CHANGE IN IT MONDAY MORNING I WILL GIVE THEM THIS INFO MAYBE COIL, OR ENGINE BEARING WISH ME LUCK.
SYKOKIDD is offline   Reply With Quote
Old 11-26-2006, 05:22 PM   #10
dcrusupra
dcrusupra's Avatar
No need to yell lol.
New Rebuild
My CarDomain
My Supra died today :( Sinistral MKIII Supra 3 01-22-2008 12:58 AM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
Engine DIED SilenceboneSupra MKIII Supra 2 10-18-2007 08:27 PM
Fuken BS died at idle while it made pop noise 88Tsupra MKIII Supra 5 07-17-2007 05:52 PM
Think my stock BOV just died sexy91tt MKIII Supra 6 02-09-2006 08:40 PM
