Old 09-21-2006, 07:51 PM   #1
Bill UK
AEM EMS
Bill UK's Avatar
Default Unknown Object
Not sure what this is at the bottom of the hole, checked the parts catalogue the nearest I can see it being is a union for cylinder head. What does it do? as you can see its almost looks like a ball bearing.
Location: inlet side of cylinder head at the very front.
Old 09-22-2006, 12:54 AM   #2
I believe it is a machining hole use during manufacture of the head. Thats why they plugged it off, as it is no longer needed.
Old 09-22-2006, 09:44 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Seams odd Mr Nickleye Toyota never blocked it off with a large grub screw like they did with the oil gallery at the front and rear of the block.
Old 09-23-2006, 12:42 AM   #4
I suspect the hole that has a threaded plug in it had something threaded into it at the factory. Why else to spend $$$ threading it??
While the other hole was simply a drilled hole to access a galley, or tie in 2 passages.
Machining blocks is a complicated affair. And then imagine an assembly line. So they have to do it as efficiently and quickly as possible.
Old 10-01-2006, 05:14 AM   #5
they probably threaded the oil galleries to make for easier cleaning of the galleries when taken to a reconditioner
3 unknown hoses Metalshredder_25 Non-Generation Specific Questions 2 06-09-2008 07:41 AM
unknown noise hkssupra MKIII Supra 5 09-22-2007 11:59 PM
unknown hose marc MKIII Supra 4 12-13-2006 04:03 AM
Unknown hose Deputy99 MKIII Supra 7 07-28-2006 10:59 PM
help!!! unknown part Deputy99 MKIII Supra 5 07-28-2006 02:11 PM
