Old 05-28-2006, 09:36 PM   #1
Metalshredder_25
Metalshredder_25 is on a distinguished road
Question unknown trouble light
this mourning when I started my car a light lit up on the very far left of my dash that kind of looked like some kind of filter, it stayed on for about five minutes then went out.I checked my haynes manual and the online tsrm and it is not listed, does anyone know what it is?
Metalshredder_25 is offline   Reply With Quote
Old 05-29-2006, 06:11 AM   #2
dcrusupra
dcrusupra's Avatar
The birdcage. Lol.
Fill your overflow bottle.
New Rebuild
My CarDomain
Old 05-29-2006, 06:16 AM   #3
low coolant level light i would imagine
top up your coolant bottle in the engine bay
Old 05-29-2006, 06:44 AM   #4
Metalshredder_25
Thank you very much, I almost tore most of my hair out trying to figure out what that stupid symbol stood for.
Old 05-29-2006, 03:45 PM   #5
dcrusupra
dcrusupra's Avatar
Lol. I cant do that. I'm only 19 and im already starting to have a bald spot. Probably from the Supra.
New Rebuild
My CarDomain
Old 05-30-2006, 02:16 AM   #6
Supra2NR
Supra2NR's Avatar
thats funny , cuz im growing grey hair, dunt know if its the supra or my girl or worst ,,,,,BOTH
Old 05-30-2006, 03:21 PM   #7
theWeezL
theWeezL's Avatar
my birdcage light came on the other day right after flushing the system and blasting water down in the overflow bottle with a pressure sprayer. Basically there is a float in the bottom of the tank and apparently it can get stuck now and then...so keep that in mind as well.
____________
Old 06-03-2006, 01:41 PM   #8
Spudboy
Spudboy's Avatar
Wink
Also be aware that if that overflow light is coming on consistently, asking for more fluid on a regular bases this may be the first sign of a leak somewhere in your system. Not uncommon initial signs of a bad head gasket.
Old 06-04-2006, 07:00 PM   #9
Metalshredder_25
lately after driving a bit hard coolant has been coming from around the top of my rad where its crimped together, I've felt the coolant and it's not that hot so hopefully it's just a faulty rad cap and not a bhg.
Old 06-04-2006, 07:08 PM   #10
Spudboy
Spudboy's Avatar
Any leak in your coolant system (like a leak in the radiator cap) can make your car run hot. Liguids boil at a higher temp. when under pressure. Your coolant system when tight is under pressure. If you have a leak somewhere it is under less or no pressure causing the coolant to boil and not do it's job.
Running hot will cause, among other things, bhg's.
Change the cap NOW.
check engine light trouble tak2099 MKIII Supra 11 05-02-2008 11:52 AM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
Possible Alternator Trouble? Lunch2000 MKIII Supra 5 03-11-2007 03:22 AM
