Old 05-20-2006, 10:56 PM   #1
bigberm
bigberm is on a distinguished road
Default Brakes
I have a 1986.5 supra and I changed the rear break pads and now the rotor heated up almost red hot. I noticed the old inner pad was worn uneven,is my caliper the problem . pls help thks
bigberm is offline   Reply With Quote
Old 05-21-2006, 05:15 AM   #2
It could be the parking brake dragging. It could be the caliper keeping pressure on the pads.
Old 05-21-2006, 09:40 PM   #3
bigberm
I wonder why the pad would wear uneven,never seen that before.
Old 05-29-2006, 11:29 PM   #4
hobbes
hobbes is on a distinguished road
It might not have uneven wear.. it may just be warped from overheating. Thats what happened to my motorcycle pads.
hobbes is offline   Reply With Quote
Old 05-30-2006, 03:07 PM   #5
theWeezL
theWeezL's Avatar
I just changed my front calipers becuase of a similiar issue. The rotors were warped because the caliper was not "free floating" like its supposed to.
I havent gotten in to my rear brakes yet, but if they are like the front there are two bushings that allow the caliper to slide back and forth to remain centered over the rotor. On mine the top bushing was rusted almost completely solid and not only was I getting uneaven pad wear, but the brakes were dragging and heating up the rotors. Thanks to my parts car I swapped em out in less than an hour and everything is all good now.
check your calipers for this condition.
____________
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
13 inch Wilwood MKIII front brakes ARZ Arizona Performance 0 03-16-2007 07:57 AM
Brakes 5M Vs. 7MGTE panda-supra MKII Supra 3 03-22-2006 09:07 AM
Brakes acting up maksimus54 Non-Generation Specific Questions 4 07-06-2005 11:47 PM
