Old 05-12-2006, 02:04 PM   #1
wesbam1
wesbam1 is on a distinguished road
Question supra 3 manifold gasket
hi, my exhaust manifold gasket has started blowing on no6 cylinder ,my local toyota dealers have told me it might need helicoiliing (a head off job apparently as anyone out there had this problem ,anyone got any info on prices ,parts and labour time required etc.thanks.
wesbam1 is offline   Reply With Quote
Old 05-12-2006, 03:13 PM   #2
ddmcse
ddmcse's Avatar
Cool
missing profile info
i don't know if you are N/A or turbo
if it's a turbo you might want to check out the downpipe .
the downpipe has an accordian looking section . it is common for this section to crack
this would fool you into thinking #6 is leaking .
check with your hand on a cold start put the hand just below the turbo heat shield and the very back of the shield .
the manifold bolts needing a heli-coil is common too so it could be both or one .
any cylinder to heli-coil would be better than #6 it's too tight back there
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-12-2006, 06:29 PM   #3
wesbam1
I checked to see where the gasses are escaping and its right on the end of the manifold by the bulkhead Id say about two inch of the gasket is lettin out gasses,its the turbo model ,I gather the turbo would have to come off to do the job ?thanks
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
3Rd gen turbo supra exhaust manifold donutking MKIII Supra 0 10-04-2005 08:49 PM
