Old 04-02-2006, 07:13 PM   #1
TRAFIK
TRAFIK's Avatar
TRAFIK is on a distinguished road
Default Hot Tranny
Dose The Mkiv Auto Tranny Normally Get Really Hot,,
Because The Shift Indicator Plastic Cover Get So Hot That I Cant Touch It. It More On The Driver Side ( Left ) Close To The End Before The Consol ... After Like 30 Min Of Driving Gets Super Hot.
--===Give me 2jz-Gte or give me death!===--
TRAFIK is offline   Reply With Quote
Old 04-03-2006, 12:11 PM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
have you checked to make sure the tranny cooler isn't blocked?
maybe install an aftermarket one and a temp gauge to see what the temps are really getting to
Pics of my build.
Do a diagnostic first!
Old 04-03-2006, 07:58 PM   #3
TRAFIK
TRAFIK's Avatar
I got a aftermarket cooler ( big ) and a pwr radiator, just chaned the tranny fluid also ( levels are fine ) both pwr and the cooler are new.
Old 04-07-2006, 01:45 AM   #4
mrnickleye
mrnickleye's Avatar
Wink cooler is kool
Does the tranny oil run into the radiator??? If not, the add-on cooler must be VERY big to cool down the oil. In fact, you may want to put one of those coolers on that come with its own fan.
As I'm sure you are aware, for every 20* temp drop (cooling) of the tranny oil, you will double the life of the trans. Trannys generally run at about 170*.
http://www.perma-cool.com/Catalog/Cat_page02.html
Old 04-07-2006, 06:14 AM   #5
TRAFIK
TRAFIK's Avatar
NO , the only cooling the fluid gets is from a trans cooler a bit bigger than this one http://www.coximports.com/BMR-70255 which sits in front of the radiator fan.
P.S I dont think any aftermarket preformance radioators like pwr, fluydine, koyo have a trans cooler in them.
Old 04-11-2006, 01:38 AM   #6
mrnickleye
mrnickleye's Avatar
So, then, what you are saying is that you are using a cooler that has NO seperate fan, and is only about 12"x6"x3/4", right?
Without running the oil into the radiator (which, by the way, coolant disepates heat 10x quicker than air), or one with its own fan, you need a cooler the size of your a/c condensor (in my opinion).
Old 04-18-2006, 01:45 AM   #7
TRAFIK
TRAFIK's Avatar
My cooler measures 12x 11x 1 1/2 and is 1 inch apart from the radiator fan.
Like I said before, I dont belive any aftermarket preformance radiator such as koyo , pwr, or fluydine has a tranny cooler in their radiators. I have pwr
the reason I ask is that I know many ppl that have tranny coolers way smaller then mine and are fine, and I got second biggest avalible from my company.
http://www.importperformancetrans.co..._4588_edit.jpg
Old 04-19-2006, 11:36 AM   #8
scruffboy
scruffboy's Avatar
Default Hot Tranny
This guy says he's feelin the heat on the shifter inside the car. Is it at all possible he has a bad cat that's heatin up and causing that. My center console used to get hot till I changed the cat. Just wonderin.
Scruff
Old 04-20-2006, 03:41 AM   #9
TRAFIK
TRAFIK's Avatar
IT DOSENT HAPPEN ALL THE TIME , sometimes it dose and sometimes it dosent. is there like a pump the recerculates fluid in the tranny? cuz i dont know , to me it feels like sometimes when the tranny gets hot the fluid is just sittin and not goin in the cooler.
Old 04-20-2006, 05:57 AM   #10
mrnickleye
mrnickleye's Avatar
Normally the fluid flows all the time. You can get an after-market trans oil temp gage to monitor it.
Tranny ? Need Info! SilverBullet05 Non-Generation Specific Questions 0 07-07-2008 09:45 PM
Auto Tranny Issues? jbjorndal MKIII Supra 3 03-14-2008 09:31 AM
Mk2 Tranny Conversion panda-supra MKII Supra 5 02-28-2006 06:04 AM
