Old 10-17-2005, 10:54 PM   #1
joebuffalo
joebuffalo is on a distinguished road
Default Headgasket question?
I have a 1989 w/7Mgte turbo motor. I just re worked the whole motor about 18.000 miles ago....complete overhaul including head rework. (stock head gasket new bolts but only torqued to 58 ft lbs) Recently I have been losing engine coolant and running rough. I pulled the top end off and found a broken insulator on #6 plug. We did a compression check and all cylinders checked between 115-120. replaced the plug and re-torqued head bolts again only to 58 ft lbs. Only 3 head bolts (around #6 moved at all and then only slightly) We also found a small leak on the little cooling hose under the thermostat housing. Engine runs smoth now but I still seem to be losing engine coolant and running a little hot. Thermostat replaced no change.I don't see any white steam in the exhaust but can feel a little moisture. Is it possible that I am leaking a small amount by the headgasket? If so does anybody think re-torqing the head to 72 lbs will help? (just discovered this forum and all the great helpful info yesterday!!) Is there any way to tell for sure if the gasket has blown again?
joebuffalo is offline   Reply With Quote
Old 10-20-2005, 10:00 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
bolts should have been torqued to 72ft lbs initially not 58
go to your local mechanic and get a block check done...
your cyl compression #'s are not very good... when did you do your check.. cold or warm?
Pics of my build.
Do a diagnostic first!
Old 10-20-2005, 01:58 PM   #3
joebuffalo
Thanks Supragirl!. I know NOW about the 72 ft lbs on the head. (A little late unfortunately!) The compression check was done after the car had sat about an hour or so and then whatever time to take everything off to get to the plugs.
What exactly do you mean by getting a block check?
Old 10-20-2005, 11:51 PM   #4
mrnickleye
mrnickleye's Avatar
Wink
The mechanic will use a special chemical and testing apperatus to test the cooling system for combustion chamber gasses leaking into the coolant.
In our cars, this will most likely mean a BHG. Usually not a cracked head. Most heads can be cleaned up and resurfaced and reused.
Also, I almost missed this thread. You should ask questions on the model specific, or general section of the forum.
Old 10-21-2005, 01:46 PM   #5
joebuffalo
Thanks Mr. nickleye. I am a newbie to the forum. I assure you I will do better next time!! Thanks for the response.
Replacing the headgasket burton51m Show n Tell 4 07-12-2010 04:47 AM
prepping block for headgasket question dannydavi MKIII Supra 1 12-06-2008 07:44 AM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
How to do a HeadGasket Job SupraSaver87 Non-Generation Specific Questions 3 09-08-2006 02:22 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
