Old 06-09-2010, 04:00 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
BOV and BPV protect against compressor surge as the throttle plate is closed. With an auto, the throttle plate is typically closed less frequently than with a std transmission. However, there are still times that the driver may close the throttle plate abruptly while building boost. This scenario would benefit from having a BOV or BPV installed (correctly) on the vehicle.
Intake Valves Clearance Adjustment question donkey MKIII Supra 1 09-14-2009 02:45 AM
Some good info on Blow off valves mkiiisupra MKIII Supra 2 01-11-2008 02:13 PM
Valves, Cams,& the works carfanatic89 MKIII Supra 6 06-06-2007 04:02 AM
Do the MK3's have blow off valves? XKeyLocX MKIII Supra 5 01-30-2006 07:06 PM
Blow Off valves? lildawg720 MKIV Supra 9 06-13-2005 08:40 PM
