Old 06-18-2009, 02:30 AM   #1
mikeoc1
mikeoc1 is on a distinguished road
Default o/d off light
previos owner of my 88 did an auto to manual tranny swap. He never had the speedo hooked back up. I got the lower speedo cable from toyota and it works fine. But now the o/d off light blinks constantly. Besides cutting the wire behind the dash, any suggestions ?
mikeoc1 is offline   Reply With Quote
Old 06-18-2009, 03:47 PM   #2
GettaRobo
GettaRobo is on a distinguished road
Check your transmission for error codes, that's why it is blinking. Jumper terminals Tt and E1 in the diagnostic port with the car off and key switched to on. Make sure O/D is on. The O/D will start flashing in a series of blinks to show one or multiple error codes. Hope this is helpful!
GettaRobo is offline   Reply With Quote
Old 06-18-2009, 07:44 PM   #3
dannydavi
dannydavi's Avatar
Mine was doing this too because of the Speedo cable. Once i got my speedo replaced on my auto tranny car it went away. I only replaced the bottom as well.. So it appears it is something to do with the swap, but what I don't know unfortunately.. perhaps all you need to do is reset the codes. try unplugging the battery for a couple minutes.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 06-19-2009, 02:41 PM   #4
mikeoc1
it has a manual trans in it now so I figure the car thinks its not in o/d since nothng is connected to that plug/od switch in the console. I may try and just jump the switch so it thinks the o/d is on all the time.
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
light issue kewlcoconut MKIII Supra 5 11-24-2005 04:28 AM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
