Old 03-13-2009, 03:40 AM   #1
georides
georides's Avatar
georides is on a distinguished road
Default Rust in the Coolant - Run with No Thermostat?
Hi guys,
well we had some problems now that the 87 non-turbo automatic is on the road and registered. Left it to my bro for the weekend, comes back the radiator hoses are practically hanging off and theres hardly any coolant in the machine, overheats while idlling and I'm just messing with the distributor.
We decide to take it out for a drive, should have been forewarned about the white smoke coming out the tailpipe, HEADGASKET
Thing overheats, there's more pressure in those radiator hoses than I've ever seen (I had put a clamp on one, which was a bad idea, no heat coming out the core, we decide to nurse it back to the house 5 miles.
Installed the "double money back guarantee" K&W Nanotechnology head gasket sealant as a try before taking off the insurance to change the head, will report later on this.
THE QUESTION:
Should have known from the get go when this car was donated, massive amounts of rust in the cooling system, can't get rid of the brown water. Original thermostat was stuck open.
Tempted to leave the new one out, judging from how well the thermo housing sealed today when running the treatment.
Would be the horror to have the thermo be stuck CLOSED!
georides is offline   Reply With Quote
Old 03-13-2009, 03:44 AM   #2
Sellenzz
Sellenzz's Avatar
Sellenzz is on a distinguished road
do not let your bro drive it
Sellenzz is offline   Reply With Quote
Old 03-13-2009, 02:02 PM   #3
georides
georides's Avatar
Yes, agreed, although deal was he pays for the parts and I do the work (with him). He needs a car
So verdict on the thermostat? Some say low engine temps will increase blowby and lower time to closed-loop (MPG).
Old 03-15-2009, 04:57 AM   #4
georides
georides's Avatar
OK little questions here:
Removed the thermo in regards to no/low flow through the system, seems the overheating issue is a thing of the past.
However, bro comes back after trip to NYC and back with the radiator hoses hanging off again, one of them, the upper, which appeared OK has a solid burst tear about 4 inches closer to the thermostat housing (which by some miracle happened about 10 feet from our apt).
Seems we have overly high pressure in the system, HEAD GASKET ISSUE?
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
