Old 09-30-2008, 07:59 PM   #1
spoolin_supra
spoolin_supra's Avatar
spoolin_supra is on a distinguished road
Default Help with new gauges!!!
Hey guys I just got my hands on a boost gauge and air/fuel ratio gauge. On the air fuel where does the purple wire go when you are running a catless straight pipe exahaust? and on the boost gauge where is the best place to tap into the vacuum line? Thanks!!
mk3 rims
2.5 straight pipe (catless)
stock turbo
HKS ssqv bov =]
racing suspension
ACT clutch
marlinecrawler shifter seat and bushing
auto-meter boost and air/fuel ratio gauges
spoolin_supra is offline   Reply With Quote
Old 09-30-2008, 08:47 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
I connected the boost gauge to the pipe going to the pressure sensor using a T connector, the air/fuel gauge wire I connected to the odd coloured wire going to the oxygen (lambda) sensor. There are three wires for the oxygen sensor, two are the same colour and one is a different colour, splice in your purple wire to the odd coloured wire.
Pressure Sensor
Old 10-01-2008, 12:06 AM   #3
spoolin_supra
thanks a bunch im guna have a go at it in a little while ill let you know how i do!
mk3 rims
stock turbo
HKS ssqv bov =]
racing suspension
ACT clutch
Old 10-01-2008, 01:13 PM   #4
spoolin_supra
the o2 sensor is by the cat isnt it so if i have a catless exhaust will the guage still function properly?
mk3 rims
stock turbo
HKS ssqv bov =]
racing suspension
ACT clutch
Old 10-01-2008, 05:39 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
The o2 (oxygen) sensor is located on the exhaust elbow (marked with a yellow arrow) make the connection in the cable as faraway as possible from the heat. I connected mine where the wires run near the cam-positioning sensor.
PS. I have no cat’s only one dog.
Old 10-01-2008, 06:30 PM   #6
Cool
lol
it measures way before both the pre cat and the main cat
Old 10-01-2008, 09:47 PM   #7
spoolin_supra
boost gauge = sucessful
i am going to attempt the air/fuel now
thanks!!!
mk3 rims
stock turbo
HKS ssqv bov =]
racing suspension
ACT clutch
Old 10-01-2008, 10:38 PM   #8
spoolin_supra
ok i started wiring it but it started raining so i am going to have to finish it tomorrow. Behind the turbo I see 3 wires running into a thin bar then piping and 2 are black and on 1 blue so i am guessing that i tap into the blue?
mk3 rims
stock turbo
HKS ssqv bov =]
racing suspension
ACT clutch
Old 10-02-2008, 10:19 PM   #9
Bill UK
AEM EMS
Bill UK's Avatar
Yep! that sounds ok, the other two are heater wires.
Old 10-02-2008, 10:23 PM   #10
spoolin_supra
ok i hooked it up and nothing its going on. when the purple wire wasnt connected it just read rich to the max all the time but now that i hooked it up it and when i start the car it shows lean then goes to nothing. Do I need to be traveling fast for it to kick in I didnt drive it really just revved.
mk3 rims
stock turbo
HKS ssqv bov =]
racing suspension
ACT clutch
TRD Gauges Help needed ladyangel MKIV Supra 1 06-24-2008 11:12 PM
new gauges Supra2NR MKIII Supra 6 09-19-2007 06:06 AM
Gauge Pods...more gauges Burning Pyro MKIII Supra 3 07-24-2007 03:08 PM
Gauges Burning Pyro MKIII Supra 3 07-21-2007 07:07 AM
