#1 | |
#2 |
That is helpful do. Do you by any chance have a bit more detail on the recirc to the BOV possible of any vacuum diagrams as well. I have looked high and low for the info and cannot seem to find it.
#3 |
the only real diagram I have is in my head lol. I could try to help you through pictures? The reason I asked about the BOV is beacause if it's a stock BOV and it's not recirculating back into the intake, you're basically causing yourself a large vacuum leak. I learned this the hard way.
#4 |
Ok. The BOV is stock. Now what your telling me if I am correct is the vacuum line that is on the stock turbo loops from the turbo to the actuator/BOV. Right? Then off the intake boot down to the power steering pump off there across the front of the engine up the intake side to the I forget what its called on the fuel rail so the whatchamajigger (pressure regulator?) then into the intake. Correct? Thats how mine is ran off the top of my head. When you recirculating to the intake. I guess I would need an example or explanation. Im not interpreting how to do that. If its not like that stock. Anyway. Appreciate the help hope to hear back on this one.
#5 | |
3 inch exhaust, cometic head gasket, arp studs, lexus afm, 550's, custom front fed intake manifold, FM intercooler, daily driven at 12 lbs.] |
#6 |
Right on. It is what its supposed to be if Im putting the info to my brain correctly. Now that I believe it is the issue this whole time. Because she spools blows of the steam. You know what I mean. My ? on the the vacuum now is the Turbo Pressure Assy. on the driver side inner fender the vacuum line runs from there to the cruise control acuator along the firewall T's into the intake nipple across the firewall to the heater vacuum somn or other I have looked and looked and asked trying to find where or what I'm missing because I believe my problem lies amongst that road. ????
#7 |
1990 Toyota Supra Turbo A/T ------------------------------------------------ Questions about oil? take a look http://www.supramania.com/aehaas/ |
#8 | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| low boost psi, wtf | supradad86_5 | MKIII Supra | 4 | 02-09-2014 02:05 AM |
| wont hold boost | Supraman | MKIII Supra | 12 | 04-19-2007 04:52 AM |
| issue w/ boost spikes? i think? | NOTORIOUS VR | Non-Generation Specific Questions | 17 | 01-17-2007 08:35 PM |
| installing manual boost controller 1989?? | hamburgler | MKIII Supra | 4 | 07-13-2005 12:55 PM |
| No boost in neutral but boost in gear! | edgardo | MKIII Supra | 5 | 10-09-2004 04:01 AM |
