Old 07-09-2005, 09:51 PM   #1
Supra Guestmk3boy
Guest
Posts: n/a
hi every one i have an mk3 and the tranny gears grind so i have a non turbo tranz to put on my car will it work? plz plz plz plz plz plz plz plz plz plz plz plz plz............................help me!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-09-2005, 10:43 PM   #2
monkihead
SP58GT
monkihead's Avatar
uh, probably but i'd need more info on ur car....
monique- better off dead
Old 07-12-2005, 09:07 AM   #3
Poodles
Poodles is on a distinguished road
I believe it will bolt up, but if I recall correctly the Turbo's had a beefer tranny from the factory then the NA Supras. It might work...but I don't think it will take the strain for long. Get the tranny rebuilt by a good shop (I believe marlincrawler.com does them, and yes it's for trucks, but they used the same trannys in the later model trucks, and he rebuilds em stronger and his price was a LOT lower than the local shops in my area). Or just look for one of the trannys from one of the later model trucks (NOT a 4x4, as the input shaft is different so it can mount to the transfer case). I was going to buy a Supra with a messed up tranny so I found out as much info as I could on this...
BUT, it might not be the tranny, it COULD be the clutch system. Clutch might need to be replaced, your slave/master clutch system might be bad, or it might be low on fluid causing it not to disengage the clutch all the way.
Hope this helps.
P.S.
First post, hiyas B)
Poodles is offline   Reply With Quote
Old 07-13-2005, 12:01 PM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
if you desperately need it to run your car it will bolt up fine... i'm not sure on the bellhousing between r154 and w58 tho... altho block bolt pattern is the same.. is the gearbox boltup?
it will work tho
just make sure it has a bellhousing and get a clutch kit etc as they use different clutches
Pics of my build.
Do a diagnostic first!
Haha.....Read these Emails about SUPRAS FOR SALE Metalluthier Non-Generation Specific Questions 54 04-25-2011 11:51 PM
What threads to read first? mikegladsz Off Topic Forum 1 02-02-2007 02:20 AM
You all need to read this, it just might mess you up. Be warned! joel w Off Topic Forum 2 09-03-2006 08:16 PM
Please Read, Important j3pz Non-Generation Specific Questions 0 06-17-2006 08:37 PM
