Old 07-08-2005, 09:04 PM   #1
lilsmitty
lilsmitty is on a distinguished road
My supra is acting really weird, that battery dies when its sits overnight and i got the battery tested. Its good. and when i run the car it seems to charge up to 18 volts when i hit the gas. Like a spike or surge. I but i dont think the alternator is bad. anyone have any ideas?
lilsmitty is offline   Reply With Quote
Old 07-09-2005, 12:12 AM   #2
monkihead
SP58GT
monkihead's Avatar
then you may have a short somewhere in your electrical system.
monique- better off dead
Old 07-09-2005, 03:52 PM   #3
KingDiamond
KingDiamond is on a distinguished road
Well first off if your charing system is charging at 18 volts then your voltage regulator is probably shot, its not suppose to charge that high. Second, if your battery is dying overnight then you probably have what they call a parasitic draw, something in your electrical system is pulling battery power constantly, such as monkihead said a short in your electrical system.
KingDiamond is offline   Reply With Quote
Old 07-09-2005, 04:25 PM   #4
monkihead
SP58GT
monkihead's Avatar
:blink: parasitic draw?? is that the tech term?? it sounds like a tick, almost evil.
Old 07-09-2005, 06:13 PM   #5
lilsmitty
Well if the voltage regulator is shot would that drain the battery if it got wet?
Old 07-09-2005, 07:17 PM   #6
monkihead
SP58GT
monkihead's Avatar
possibly. just take off the alternator to get it checked.
Old 07-09-2005, 07:33 PM   #7
lilsmitty
Where is the voltage regulator located?
Old 07-09-2005, 10:48 PM   #8
monkihead
SP58GT
monkihead's Avatar
its internal, i believe...alternator
Old 07-15-2005, 11:32 AM   #9
Metalluthier
Metalluthier is on a distinguished road
I've had similar problems, except it was with my sub system. I had it hot constantly, so I wired a switch up to the deck - Sub antenna to turn it off when I was done with it, seemed to fix the problem. If your battery is fine, it could be an ignition relay or main relay. Have you checked your fuses? It could also be that you need to replace your positive battery cable clamp. Cars suck like that, haha
Burzum - Die Liebe Nerpus
"I am a man and I hold in my hand my fate" - Quorthon
Metalluthier is offline   Reply With Quote
Old 08-09-2005, 02:00 AM   #10
lilsmitty
Does anyone know any good websites i cant get Really good vacum line and air intake line diagrams???????
