Old 02-17-2008, 02:35 AM   #1
tcrawman
tcrawman is on a distinguished road
Default 86.5 Manual non-turbo will not start!!
This is the second time in a month this has happened. I get in the car turn the key and nothing. All the lights come on, radio comes on but there is no crank or anything. I've tried to arm and then disarm the factory alarm but still nothing. Anyone have any ideas?
tcrawman is offline   Reply With Quote
Old 02-17-2008, 03:37 AM   #2
Timtation
Timtation's Avatar
Timtation is on a distinguished road
Default transmission switch
Try putting it in neutral and then starting, could be a switch on your transmission. I had a similar problem on my mazda protege.
Timtation is offline   Reply With Quote
Old 02-17-2008, 05:00 AM   #3
tcrawman
Default It's a manual trans
It's a manual transmission so I've tried that. Even tried putting it in gear to start it.
Old 02-18-2008, 01:35 AM   #4
Busted Knuckles
Busted Knuckles's Avatar
Do you hear a click? If so, the starter is bad, and needs to be replaced. If not, check the clutch safety switch. There is a switch on the clutch that is supposed to keep the starter from engaging when the clutch is out. You are pressing the clutch in all the way, right?
Old 02-18-2008, 03:02 AM   #5
scruffboy
scruffboy's Avatar
Default Maf?
Could the MAF come loose? This will prevent it from turning over.
The only way they'll get my Supra is to pry my cold, dead fingers from the steering wheel.
89 N/A Supra, 5 speed, TEMS, Moon Roof, all stock, Black with beautiful Burgundy interior, lots of new parts, oil changed every 3 months like clockwork.
Old 02-18-2008, 04:59 PM   #6
tcrawman
Default Started
It turned out to be a wire that came out of the alarm, so I reconnected it in the morning and it fired up fine. Going to get the schematics for the factory alarm and just bypass it all together
89 7mg to 2jz turbo manual turbojuiced MKIII Supra 2 04-05-2008 01:11 AM
86.5 Manual non-turbo will not start!! tcrawman MKIII Supra 7 03-31-2008 09:13 PM
