Old 10-22-2007, 06:24 AM   #1
SupRa_b0y
SupRa_b0y is on a distinguished road
Unhappy accleration
i changed all the front seals and my valve cover gaskets, and now my car is not accelerating rite? it just doesnt want to go! why?? i rechecked everything 10 times!!
SupRa_b0y is offline   Reply With Quote
Old 10-22-2007, 03:05 PM   #2
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
is it turbo? if so are you geting any boost? if not is the idle ok are there any vacuum leaks. if you dont know take a bottle of carb cleaner and spray it on the throttle body and other tubes if the idle goes up you found a leak.
another prob could be. did you take off the tps or move it at all?
Supra_87_mk3 is offline   Reply With Quote
Old 10-23-2007, 12:57 AM   #3
mrnickleye
mrnickleye's Avatar
Sounds like your timing belt may be a tooth off.
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
