Old 01-25-2005, 08:52 PM   #1
mike
Guest
Posts: n/a
Did toyota produce a single turbo MKIV supra? Or was it just non-turbo and twin turbo?
Old 01-26-2005, 09:27 AM   #2
i think a huge ass single turbo one from the factory would have been cool but no they only did non turbo and twin turbo
Old 02-12-2005, 09:39 AM   #3
supra_lover100
supra_lover100 is on a distinguished road
honestly though who cares about single turbo when you can get twin turbos?
supra_lover100 is offline   Reply With Quote
Old 08-20-2005, 03:35 PM   #4
evenflow
evenflow is on a distinguished road
Actually, the single turbo conversion Supra's may be able to pull more HP, simply because it's hard to fit two huge ass turbos into that space.
evenflow is offline   Reply With Quote
Old 08-20-2005, 05:51 PM   #5
SupraMan1784
there are twin turbo upgrades...i know hks and greddy have them, single turbo gets more power....though upgrading to dual turbos also gets u a good amount of power...it just depends on how u want the car to engage the boost
Now: Saving for an MKIV
Broken Rides:
Old 08-20-2005, 07:17 PM   #6
SuperSupra86
SuperSupra86 is on a distinguished road
Well with Toyota they sent the TT into a perfectly smooth sequential boost.....A single larger turbo tends to get more Torque in low ranges where as the TT you have higher range Torque and HP due to Turbo Lag, etc....I've seen some single Turbo MKIV people have modded and they are incredible beasts off the line, but generally the TT set up tops out at a higher Max Speed...Just my two cents on the set ups i've seen
Who needs zoom zoom......I got turbo!!!
SuperSupra86 is offline   Reply With Quote
Old 08-21-2005, 05:51 AM   #7
Guest
Guest
Posts: n/a
Actually you have it backwards, A single will give you less low end power and more grunt at the top end. The stock twins will spool quicker so you get tourque lower in the rpm range.
And single turbo upgrades will make more power, more efficiently than the stock twins will.
Old 08-21-2005, 08:31 PM   #8
SupraMan1784
yea...i was about to say u switched them but you had the right idea
Broken Rides:
Old 08-22-2005, 12:21 AM   #9
Poodles
All of that depends a LOT on the turbo itself and it's dimensions. You tune a turbo to when you want the power to kick in. The main reason people go to a single turbo it seems is quite simple....cost. One turbo is far cheaper than 2, going fast on the cheap is usually what people are after.
As it was said, the twins will spool faster, getting the power faster. Also, it's a lot smoother, and has a flatter power band with far less peaking than a single turbo. That can be tuned a lot by the sizing of the turbo components, most good places will ask the simple questions, when do you want it to kick in, how much total boost, how will it be driven, ect.
Sidenote: ball bearing turbos give no power gain, they just spool faster leading to better 1/4 mile times because the boost comes in faster.
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
I need you guys opinion on this 1994 Supra Jiwon Non-Generation Specific Questions 2 06-14-2006 01:58 AM
