Old 12-30-2005, 05:34 PM   #1
panicos
panicos is on a distinguished road
Default Idle Problem. Please Help
My Jza80 TT wont start in the morning unlless I have my foot on the throttle. When it warms up then it will idle at 500pm. It seems like the Idle control valve does not take any commands from the Ecu. Please give me a few guidelines, suggestions on where to look for the problem. Thanks
panicos is offline   Reply With Quote
Old 12-30-2005, 06:33 PM   #2
Do you have a copy of the TSRMs? I'm sure there's a troubleshooting section for the IACV. Imo, the TSRMs are a 'must-have' for all Mkiv Supra TT owners that want to do their own maintenance and modifications.
Old 12-30-2005, 07:00 PM   #3
panicos
My car is Jap Specs and Jap Import. I have nothing. My michanic is unable to locate the problem and my only way is to sort out my self with the help of you guys.
Old 12-30-2005, 07:09 PM   #4
In that case, troubleshooting will be more difficult. As a first step, I'd suggest finding another Supra owner that lives near you to see if they'd let you swap their IACV temporarily. If that fixes the problem, all you need is a new IACV from Toyota...
Old 12-30-2005, 10:44 PM   #5
have you tried running a diagnostic?
Old 12-31-2005, 02:27 AM   #6
SKILMATIC
SKILMATIC is on a distinguished road
It may be your IACV(idle air control valve), but is there a problem with idling once the car is warm?
SKILMATIC is offline   Reply With Quote
Old 12-31-2005, 04:41 AM   #7
SKILMATIC
I know you said it idles when it is warm at 500rpm but do you notice any flutering at all? Anything different? Is it at all slugish?
Its just kind of odd how the IACV works fine once you are warm but during cold start it doesnt seem to work.
Do you notice any wires loose? Did you have any electrical problems before? I would try changing the IACV first then if that doesnt solve the problem we can trouble shoot some more.
Old 01-01-2006, 09:26 AM   #8
...I would try changing the IACV first then if that doesnt solve the problem we can trouble shoot some more.
Is there an echo in here?
Old 01-01-2006, 10:51 AM   #9
we won't really know much until he does at least a diagnostic... it very well may be the isc but pulling codes is always a good first step
Old 01-01-2006, 04:48 PM   #10
Agreed...if your Supra's ecu has any codes, it's always a worthwhile exercise to go through them first. Although you didn't mention the check-engine light, please post any codes stored in your ecu and we'll help you make sense of them.
need help with 7mgte idle problem MAG.net MKIII Supra 4 09-06-2007 06:10 AM
Idle Position Sensor Problem White87Turbo MKIII Supra 4 06-20-2006 05:38 AM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
