Old 11-14-2005, 04:50 AM   #1
docvtak
docvtak is on a distinguished road
Default buying a supra
I have a question in regards to buying a 93-98 toyota supra. I was interested to know what the difference between buying a twin turbo supra, turbo supra and n/a supra would be. Because I am on a budget I was interested in buying a n/a supra and swapping a 2JZ.
docvtak is offline   Reply With Quote
Old 11-14-2005, 06:06 AM   #2
TRAFIK
TRAFIK's Avatar
TRAFIK is on a distinguished road
If you are on a budget I dont think you will be able to get a TT
( unless 20K to you is being on a budget )
if you get a n/a you can pick up an engine for it starting
from $2000 - $5000 .. for example:
2jzgte complete + auto tranny: $2499 , $2800 (jdm low miles) on ebay
2jzgte complete + 6 speed $3700, $4100
I see those prices all the time and as you can see the 6 speed is more expensive and more rare therefore harder to buy.. shipping if not included will depend on where you live. around $150-$350 depending how they ship and where.. swaping is a straight drop . ( minus some small stuff like changing the Harness connector )
The differences between the TT and the N/A are:
TT has:
Bigger breaks
Turbos ( duh )
bigger stick wheels ( to clear the bigger breaks) ( duhh )
and some other stuff I dont feel like mentioning ( nothing major )
Mainly the n/a is slower.. both engines are capable of producing a lot of power and both are very relible.
The TT cost more and are every hard to find "cheap" so some people get n/a and swap in the 2jzgte.. Yes it has been done and Yes there are no problems after a proper swap..
Here is an example of what I am talking about http://www.mkivsoopra.com/project/
I'm telling you this now.. doing a good swap like "mkivsoopra" did with replacing and maintenancing several part to insure a good engine will run you about $7,000 ( engine ,shipping ,bunch or parts that mkivsoopra listed and depending if you want 6speed or not maybe little less or more )
If you dont have a lot of $$ go with a nice N/A and swap in a good motor..
You will end up with a low milage supra sooner or later if you decide to swap.
Add up the price of the swap to the price of the n/a you're getting and see if you can get a tt for that much..
ohh I almost forgot if you are not doing the swap yourself the total price of a good swap can go up to 10K , unless you skip out on the parts and get some cheap labor... Remamber I seen people buy a 2jzgte for $2300 and paying some guy $500 to swap it in.... basicly what you pay for is what you get.
--===Give me 2jz-Gte or give me death!===--
TRAFIK is offline   Reply With Quote
Old 11-15-2005, 07:21 PM   #3
Thecure634
Thecure634 is on a distinguished road
is there anything wrong with dropping in a JDM engine? like the law or not fitting becuase of the right handed drive?
Thecure634 is offline   Reply With Quote
Old 11-15-2005, 08:00 PM   #4
SupraMan1784
you could drop in a jdm engine...it doesnt matter if the car is rhd if im correct, the motor mounts in teh same place as teh usdm...so whether u get a jdm or usdm motor it will still be a straight up bolt on
Now: Saving for an MKIV
Broken Rides:
Old 11-15-2005, 08:23 PM   #5
TRAFIK
TRAFIK's Avatar
LIKE I SAID BEFORE HERE IS EVERYTHING YOU WILL NEED TO DO A GOOD SWAP
you might wanna look into getting a USDM engine.. (correct me if i'm wrong )
but you get
bigger injector
cams
bigger or better turbos , I forgot... ( jdm are ceramic usdm are steel )
and something else i forgot
can someone fill in the gaps???
Old 11-16-2005, 06:27 AM   #6
Thecure634
oh, i thought the steering column got in the way of something. maybe that was a dif. car
Old 11-16-2005, 01:29 PM   #7
SupraMan1784
when u transplant the motor...u dont have to deal with the steering column, its totally separate, the motor should bolt right in with no problems, though i havent really looked into the differences between a usdm 2j and a jdm 2jz.. i might put some research into what trafik posted....he could be correct
Broken Rides:
Buying Supra ? What To Know First mrnickleye Supra FAQ 18 12-28-2011 03:25 AM
Supra Guru's - Help buying a supra please RWD>FWD MKIV Supra 1 11-30-2008 01:09 AM
Looking into buying a supra. DavidLeClair584 MKIII Supra 2 09-26-2006 03:05 PM
