Old 06-03-2012, 05:04 AM   #1
supraa
supraa is on a distinguished road
Default supra project to 800hp
hello i want to get a supra soon and i dont know what year or engine i want. my goal is to get 800hp. i was thinking about an aftermarket turbo. what else should i get to add horsepower and keep everything from exploding. it will be a daily driver. i also want to know how much it will cost
supraa is offline   Reply With Quote
Old 06-03-2012, 03:57 PM   #2
You need to start with either a stock Mkiv Supra Turbo (which is a twin turbo) ('93.5-'02), or a modified Mkiv Supra Turbo (which usually has a single turbo kit installed, to replace the stock twins).
After you start with the correct vehicle (let's assume a stock Mkiv Supra Turbo), the rest is pretty easy (not cheap, but easy to figure out). You need a relatively large single turbo kit, a (complete) aftermarket fuel system, a fuel system controller (eg. S-AFC or AEM), and (most importantly, to keep everything from exploding) race fuel OR a methanol injection kit. If it's a 6spd, you'll need an aftermarket clutch (twin disk); if it's an auto you'll need an aftermarket torque converter and beefed up internals. Last but not least, you'll need wider rims&tires (or you'll just sit there and spin with 800hp).
It won't be cheap. The car will probably be about $25K or more (for one in good shape, if you can find someone willing to sell one in good shape), the turbo kit about $5K (with labor to install), the fuel system $2500 (with labor), the AFC about $500 or so with labor, and the race fuel is about $150 per tank (or the meth kit is about $1K with labor, and ~$20 per tank). A good clutch will be about $2k with labor, and the wider rims and tires will set you back about $4K I'd guess.
Old 06-03-2012, 10:17 PM   #3
supraa
thanks so will all this be street legal and how long do you think the engine will last(mileage wise) before i will have to get a replacement. and do you think i can do this by myself as a first time project
Old 06-06-2012, 05:48 AM   #4
Laws for street legality may vary from state to state and city to city. Here in Atlanta, it's 'street legal' as long as it still passess emissions. Here's how I take care of that:
http://www.randomtechnology.com/products.html
The engine will last for several years, as long as you continue to run enough race fuel or methanol to suppress detonation.
It's a pretty tough first-time project. I read forums/threads/etc online and studied the TSRMs for about a year before I first turned a wrench on my Supra (and I was already a decently competent mechanic before that point).
Old 08-12-2012, 01:16 PM   #5
supraa
ok im from california so im going to assume their the same. lets say my goal was was 1000hp? i want everything to be top-notch so what would be the best turbo,clutch,fuel system ect. to support all the upgrades?
thanks
Old 08-12-2012, 07:03 PM   #6
thanks
1000hp at the crank, or 1000rwhp? Big difference.
Here's a thread that details pretty much everything you need:
http://www.toyota-supra.info/forums/...ond-supra.html
You should read this thread too:
http://www.toyota-supra.info/forums/...1000-rwhp.html
Please read those two threads (every post), and then let me know if you have any follow-up questions.
88 project supra for sale mcphotolock Buy/Sell Cars 0 04-19-2012 01:59 AM
Beals' Supra Project Beals Show n Tell 1 10-02-2009 08:12 AM
