Old 09-27-2011, 11:18 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by norcalkev View Post
hey everyone Im new to the forum and new to discussing supra stuff... With that said I'm not totally ignorant about supras... I've done a lot of reading and homework. One thing I can't seem to find out is the common practice of switching a mkiv tt with the auto tranny to a manual. Is this fairly easy... would you have to switch cpu's or wire harnesses? does the auto tt have different hardware than the manual tt like the n/a does ex. heads, pistons, wheel, brakes ect? Only reason I ask is because the mkiv tt auto tranny supras are considerably cheaper and i have a fab shop that if this is a common practice I could easily do. thanks.
Maybe this is a dumb question, but if you've done "a lot of reading and homework", then why didn't you read the third thread in our MKIV FAQ?
http://www.toyota-supra.info/forums/...ing-trany.html
The auto TT has the same* hardware as the 6spd TT, except the transmission and the ecu. There are minor differences like the driveshaft length and the diff gearing*, but for the most part an Mkiv TT is an Mkiv TT. Oh, and if you're going to drag race an auto is actually faster (and more consistent) in the 1/4 mile than a 6spd...so maybe you really don't want to swap it out after all?
* Somewhat minor point: In '96-'98, the US-spec's auto diff was non-LSD (although 'yota did NOT publish this change! - for those of you ripped off, it may be too late for a class action law suit ).
Life begins at 30psi.
auto to manual tranny swap sd88supra MKIII Supra 10 11-24-2009 06:25 AM
NA to Turbo tranny swap advice Toyota Fan MKIII Supra 0 09-02-2009 08:51 PM
Tranny swap from an 88 to an 87 Cyberguy1992 MKIII Supra 2 05-27-2009 05:44 PM
Tranny Swap RedMan Non-Generation Specific Questions 0 05-24-2006 09:42 AM
