Old 09-27-2011, 06:58 PM   #1
norcalkev
Banned
norcalkev is on a distinguished road
Default Tranny swap?
hey everyone Im new to the forum and new to discussing supra stuff... With that said I'm not totally ignorant about supras... I've done a lot of reading and homework. One thing I can't seem to find out is the common practice of switching a mkiv tt with the auto tranny to a manual. Is this fairly easy... would you have to switch cpu's or wire harnesses? does the auto tt have different hardware than the manual tt like the n/a does ex. heads, pistons, wheel, brakes ect? Only reason I ask is because the mkiv tt auto tranny supras are considerably cheaper and i have a fab shop that if this is a common practice I could easily do. thanks.
norcalkev is offline   Reply With Quote
Old 09-27-2011, 11:18 PM   #2
Maybe this is a dumb question, but if you've done "a lot of reading and homework", then why didn't you read the third thread in our MKIV FAQ?
http://www.toyota-supra.info/forums/...ing-trany.html
The auto TT has the same* hardware as the 6spd TT, except the transmission and the ecu. There are minor differences like the driveshaft length and the diff gearing*, but for the most part an Mkiv TT is an Mkiv TT. Oh, and if you're going to drag race an auto is actually faster (and more consistent) in the 1/4 mile than a 6spd...so maybe you really don't want to swap it out after all?
* Somewhat minor point: In '96-'98, the US-spec's auto diff was non-LSD (although 'yota did NOT publish this change! - for those of you ripped off, it may be too late for a class action law suit ).
Old 09-28-2011, 08:43 PM   #3
norcalkev
Banned
I'm picking up on your sarcasm. look I just joined this forum yesterday and I did search through several pages looking for an answer to my question. I apologize I didn't notice the FAQ section but just because I didn't shouldn't be an indication I haven't read anything on toyota supras so ummm how about a little slack ok? furthermore, I agree auto tranny's are better for drag times as it eliminates driver error but for the supra, the auto tranny (A340E) is a piece compared to the German made V160 manual. The A340E auto tranny is the same tranny they use in the toyota tundra for god sakes. With that being said the V160 is the only option to go and so what if you have to learn how to drive the manual gearbox... doing so and perfecting would only make you a better driver. Toyota does make a powerglide auto tranny that could be potentially interesting but in my opinion I believe changing major components in a car takes away authenticity and just isn't as impressive.
Old 09-29-2011, 12:28 AM   #4
I don't disagree with anything you said, except maybe your implication that a great Mkiv TT BPU 6spd driver could beat an auto - that's never been proven (though you're welcome to try, of course!).
Please accept my apologies - sometimes I just get a bit tired of answering the same question over and over and over. My bad.
auto to manual tranny swap sd88supra MKIII Supra 10 11-24-2009 06:25 AM
NA to Turbo tranny swap advice Toyota Fan MKIII Supra 0 09-02-2009 08:51 PM
Tranny swap from an 88 to an 87 Cyberguy1992 MKIII Supra 2 05-27-2009 05:44 PM
Tranny Swap RedMan Non-Generation Specific Questions 0 05-24-2006 09:42 AM
