Old 09-17-2011, 02:57 AM   #1
deigima
deigima's Avatar
deigima is on a distinguished road
Default how much power?
how much power is it possible to squeeze out of the 2jzgte when just running pump feul?
deigima is offline   Reply With Quote
Old 09-19-2011, 03:31 AM   #2
With the oem twin turbos? ...or an aftermarket turbo+fuel system setup?
Also, can I spray methanol? How about just water injection?
Old 09-20-2011, 04:25 AM   #3
deigima
deigima's Avatar
i mean without methanol or water injection or any of that whatnot. yes, upgrading injectors and whatnot, but keeping the block internals standard. i dont think aftermarket turbos would be needed, since the most you can push without needing special injection is about 15psi,
so how much power NOT using methanol spray or water injection. preferably running 15psi.
Aussie Aussie Aussie!
should have L's but im too lazy
Old 09-20-2011, 02:25 PM   #4
... i dont think aftermarket turbos would be needed, since the most you can push without needing special injection is about 15psi,
Different sizes of turbos produce vastly different horsepower results at the same boost level. The bigger the turbo, the slower it needs to spin to push the same amount of air. Slower spin means less heat generated, which means denser air, which means more horsepower.
Old 02-28-2012, 10:12 PM   #5
deigima
deigima's Avatar
come on dude, get to the point. no bs, just tell me
Old 02-29-2012, 02:40 AM   #6
Stock twins, 6spd: 350rwhp on pump gas
76mm turbo (or bigger), 6spd: 700rwhp on pump gas
However, with the 76mm turbo, running 15psi on pump gas, you'll be running 220rwhp until you hit about 5500 rpm or so. You'll be living in turbo lag city, and it'll suck donkey b@llz.
Can you see now why I was trying to find out more about your setup? There is no one clear answer...it depends a lot on the turbo you'l be running, and your application. Maybe rediculous turbo lag won't be a factor to you, if all you'll be doing is drag racing - just drop the clutch at 6k and keep it at redline through the whole 1/4 mile. Or maybe you want to stay with the stock twins because of the cost of a single turbo and fuel system upgrade, so you'll be stuck at 350rwhp. This sh*t ain't BS buddy...it's critical information and there's no way to properly and correctly answer your question without knowing it all.
no spark chrism8799 MKII Supra 6 12-08-2008 12:38 AM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
Ghetto is a good seller ARZ Buyer/Seller ratings 0 11-15-2006 11:58 PM
