Old 09-28-2005, 04:27 AM   #1
veyspeed007
veyspeed007 is on a distinguished road
Post Why does my Supra overheats!
I have a 94 Supra Turbo and my car seems to overheat so quickly. The coolant/water gauge (not sure what you call it) pointer is steady at midpoint up until 30-45 minutes of driving. All of a sudden it creeps up to max (hot) and you can tell that it is accurate because the engine bay is so hot as I open up the hood. There are no coolant leak. There seems to be excess coolant in the reservoir but that's about it. Please help! What else could it be?
veyspeed007 is offline   Reply With Quote
Old 09-28-2005, 12:15 PM   #2
dare i say it... a 2jz with a blown headgasket?
when exactly does it overheat mainly.... traffic, highway?
does it come back down or stay up hot
does your dashboard gurgle in the mornings when you start it?
Old 09-29-2005, 06:01 AM   #3
whitetiger777
whitetiger777's Avatar
whitetiger777 is on a distinguished road
I a problem similar on an eclipse. It turned out that the thermostat got stuck. Could be the same thing, but could not be, I've never worked on a 2JZ before.
whitetiger777 is offline   Reply With Quote
Old 09-29-2005, 02:15 PM   #4
SupraMan1784
make sure your coolant levels are topped off...if they are then check to see if the radiator is leaking, maybe bhg but somehow i kind of doubt it, maybe your water pump is not working...or your oil levels are low...just makin some assumptions right now
Now: Saving for an MKIV
Broken Rides:
Old 10-03-2005, 05:42 AM   #5
veyspeed007
all great answers. thank you! i will check it out.
Old 10-26-2005, 06:14 AM   #6
insane_snowman
insane_snowman is on a distinguished road
are any of your hoses cracked? or have you done a coolent flush recently and didn't get all the air out?
insane_snowman is offline   Reply With Quote
Old 10-26-2005, 06:19 AM   #7
insane_snowman
whitetiger, you say thermostat, but if that's the issue..it will overheat in around 5 minutes because the hot coolent just stays in the engine, and supraman you say water pump..i could be, im not sure how quickly those will over heat the engine but usually if they fail, coolant steams like a mofo
Old 10-26-2005, 01:14 PM   #8
I agree...it could be as simple as a maintenance issue not flushing the coolant regularly. Several items can corrode and fail in the cooling system without regular flushes, such as the water pump, the temperature sensor for the dash gauge, and the hose coupler over your #6 coilpack. The turbo(s) make the engine bay hot regardless. Unless you actually hear the coolant boiling inside the cooling system, there may not be any problem other than a failing temp sensor for the gauge on the dash.
Old 11-12-2005, 05:56 AM   #9
veyspeed007
It turns out that one of the motor of my dual electric fan gave out, so I bought an entirely brand new Flex Lite fan and an aftermarket radiator (Koyo) with new red Toyota coolant and now the car seems to be running great. NO more overheating! Knock on wood!
what do you think of this setup? Jareduhhhh MKIV Supra 4 02-19-2009 10:38 AM
