Old 01-06-2011, 04:59 AM   #1
CustomMKIV
CustomMKIV is on a distinguished road
Default Not exactly 100%
No. I'm not 100% the wheels will fit. I've been reading all the forums to see what others are fitting on the stock body and trying to calculate how wide I can go from there. It will probably be best to get the body work done and then measure my clearances for exact fits. I was trying to figure it out so I could order the wheels since it will be at least 6 months before I can get the car in for the wide body.
CustomMKIV is offline   Reply With Quote
Old 01-08-2011, 01:04 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Your 335s will barely fit under the widebody, on the rear. Worst case, you may have to have the bodyshop modify the widebody kit, to make it 1/4" wider on the rear...and that assumes the offsets on your rims are optimal. On the fronts, 285s actually fit with the oem body (not widebody!)...again, assuming a perfect rim offset... no problem at all with rubbing (as long as you don't go crazy about how much you lower the suspension...
With a bit of work (pounding the inner fenderwells, trimming the fender lip), you can actually get 315s to squeeze into the oem fenders.
Oh, and I'm curious. For only 700rwhp, 315s are more than enough rubber to do the job. Why go widebody and 335s?
Life begins at 30psi.
Old 01-09-2011, 03:38 PM   #3
CustomMKIV
I'm actually looking into more than 700WHP. I also like the wide body and the loook of the wider wheels an tires. I'm will only lower the car as much is needed for optimum look and performance. I'm going to work with the shop after the body work is done to get the right offsets and wheel measurements. I'm thinking at least 800WHP. My original plan was 900WHP and that's more what I'm looking for.
I'm currently running a twin turbo engine in a N/A body with a stock 5 speed transmission and N/A rear end. I've got 400WHP with 410lbft of torque according to the dyno. I'm currently running it on premium pump gas.
What's the best way to get to 900WHP from where I am right now? Do I need to upgrade to the 6 speed Getrag transmission and a different rear end to handle the power? Most performance shops are recommending a total rebuild from the bottom up. My understanding is that I should be able to meet my goals without touching the internals. Any thoughts on this?
Old 01-09-2011, 05:12 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
...I'm currently running a twin turbo engine in a N/A body with a stock 5 speed transmission and N/A rear end. I've got 400WHP with 410lbft of torque according to the dyno. I'm currently running it on premium pump gas.
Yep the oem n/a 5spd won't handle 900whp, so the 6spd is a must. I don't have max hp specs on the n/a diff, but I'm about 95%+ certain you'll have to change that too.
You could run 850rwhp (6spd) reliably with the oem 2jz-gte bottom end. 900rwhp is pushing it, imo. Of course you'll need 272 cams (preferrably HKS)...and some porting on the head wouldn't hurt either. If you're going to get it ported, make sure it's by someone who can prove their results on the 2jz-gte. A bad porting job will make worse power than an oem head.
1997 TT Supra Daily Driver Ember778 MKIV Supra 3 03-27-2010 10:54 PM
Q on Daily Supra edddddy MKIV Supra 3 08-17-2008 07:25 PM
Turbo supra reliable daily driver? KhanArtisT MKIII Supra 7 01-08-2006 06:23 AM
Daily Driving Makavelli MKIII Supra 8 07-30-2005 01:33 AM
