#1 | |
Supra Owner
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#2 |
Oil level is ok. Thanks pwpanas!
I went to start it up today, and now both light are staying on... I shut it down and restarted the car (hoping the lights will go away), no luck they're still on. Any other suggestions? I also noticed that when I looked under the hood for anything that may cause the problem, I heard a hissing sound coming from the "Resistor Pack Part# 28515-46010" (at least I think it came from it) when the car was off. Is this normal and can this be the problem or is it another issue that I have? Thanks
'97 Supra TT, AT |
#3 | |
Supra Owner
If your master warning light is on, you'll be able to read the code(s) to determine the problem.
| Thread Tools | |
| Display Modes | |
