Old 11-28-2010, 06:37 AM   #1
deanja8
deanja8 is on a distinguished road
Default Both "Master Warning and BRAKE" light comes on while making a turn...
Long time reader, first time post… I need some help from the community. While slowing down to make a right turn tonight with my blinker on, the “Master Warning Light” and “BRAKE” (type A, e-brake) light came at the same time. A few seconds after the turn, they turned off. Slowing down for another turn, blinker on, and both lights came on again, but they stayed on a bit longer before turning off. Has anyone experienced this problem or know what maybe causing it?
Thanks for your help.
'97 Supra TT, AT
deanja8 is offline   Reply With Quote
Old 11-28-2010, 04:43 PM   #2
Most likely a low oil level.
Old 11-29-2010, 09:21 AM   #3
deanja8
Oil level is ok. Thanks pwpanas!
I went to start it up today, and now both light are staying on... I shut it down and restarted the car (hoping the lights will go away), no luck they're still on. Any other suggestions? I also noticed that when I looked under the hood for anything that may cause the problem, I heard a hissing sound coming from the "Resistor Pack Part# 28515-46010" (at least I think it came from it) when the car was off. Is this normal and can this be the problem or is it another issue that I have?
Thanks
'97 Supra TT, AT
Old 12-05-2010, 03:42 PM   #4
Thanks
It's not normal for the resistor pack to hiss. Although this is part of the electronics (obviously), I doubt it's related to your oil sensor.
If your master warning light is on, you'll be able to read the code(s) to determine the problem.
