Old 06-13-2010, 03:14 AM   #1
Durandal
Durandal's Avatar
Durandal is on a distinguished road
Default Idle hunting issue
I have been having an issue pop up recently now and then but not consistently. Sometimes my idle will surge from 1000 to 2000 as if I have a disconnected MAP sensor. Other times it will idle high at around 1200-1300. When I step on the clutch the idle drops down to 1000 for a second but then back to 1200-1300.Any other time it idles normall at around 1k.
I've checked for boost leaks and just cleaned my IAC valve last summer so I don't think those are the problem. Is the first butterfly closest to the front of the car in the throttle body suppose to be closed all the way? It seems to be open a little bit in the closed position.
*Should mention that I am getting no codes
Durandal is offline   Reply With Quote
Old 06-13-2010, 06:08 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Although you checked for this last summer, a boost leak could happen at any time (eg. a cracked hose). I'd advise you to check this again. Another possibility is a dirty Idle-Air Control valve.
I doubt your secondary throttle (the one for the oem traction control system) is related. This butterfly should be fully open most of the time, except when your traction control system is triggered.
Life begins at 30psi.
Old 06-14-2010, 02:37 PM   #3
Durandal
Durandal's Avatar
Yah I've been leaning towards a small boost leak. I had a boost leak awhile ago where one of the accordion style rubber pipes above the turbos was loose but I fixed that.
I had my exhaust from the turbo manifold back removed last year to look at removing the stock cats but didn't do anything with it and just put it back on. I don't think an exhaust leak there would be causing this though. I guess I'll rig up one of those homemade boost leak testers and check my IAC just to be sure.
The thing is if I keep my foot steady on the pedal under boost, my boost gauge stays constant and doesn't drop off.
*edit: Did another visual inspection today and found a couple hoses with small cracks on the ends of them at the EGCV VSV and a some above the turbos. Going to look at replacing them although they don't seem to be leaking.
I give the car a cold start and it idles at around 900 which is good, but after it warms up the idle goes up to 1100-1200. I take it for a drive to test my boost pressures and am getting around 8 psi from turbo1 until turbo2 kicks in at 4000 RPM and my boost pressure goes up to 14 psi.
I did add some fuel injection cleaner last time I got gas but that wouldn't increase my idle 200 RPM would it?
Old 06-15-2010, 12:05 AM   #4
wstanek
wstanek's Avatar
wstanek is on a distinguished road
possibly if ur injectors were clogging and that cleaned them mabey ur getting higher rpm cuz o more fuel! =D
wstanek is offline   Reply With Quote
Old 06-15-2010, 04:09 AM   #5
pwpanas
Supra Owner
pwpanas's Avatar
Agreed fuel injector cleaner wouldn't cause it. However, it wouldn't take more than a very small-sized hole to create enough of a boost leak to raise your idle. However, that small sized hole wouldn't necessarily be big enough to cause a noticeable a drop in boost pressure on the high end (total air volume is many times more under load and higher rpm while boosting).
Old 07-02-2010, 06:27 PM   #6
Durandal
Durandal's Avatar
What would cause my cold starts to not idle high at all? Right now my cold starts the same as hot starts and idle at 900 instead of over 1k like it should. The IAC is used after it warms up right? Or do I have that backwards.
Old 07-04-2010, 04:16 PM   #7
pwpanas
Supra Owner
pwpanas's Avatar
The IAC is open during starting and cold-engine operation. Throttle plate is sealed shut unless you press the accelerator. There should be no vacuum leaks other than the IAC. In other words, the IAC is the only path for air into the engine, so it must be open for initial idle. While cold, the idle rpm is higher (so the IAC is actually open its widest during cold idle); a/f is also richer during cold/cool engine conditions. The IAC closes a bit after the engine warmed up to reduce rpm.
Old 07-11-2010, 05:13 PM   #8
Durandal
Durandal's Avatar
After more troubleshooting I'm still stuck at the same spot with a cold start idle around 500-750.
*Cleaned idle air control valve and even opened up the inside of the stepper motor which was clean. Checked the stepper motors bearings and that the spring was good. Did resistance checks on the IACV and they were reading 20.5 ohms.
*Checked coolant temp sensor resistance when cold and it was 2.1k ohm
*Cleaned air intake temp sensor and checked the reading on it when cold, it was 2.3k ohm
*Checked my coolant by measuring the voltage between the negative of the battery and the coolant at the rad cap. It read 0.13 vdc, 0.1-0.5 is supposed to be good.
Is there anything else I can try? I'm not completely sure it isn't the motor on the IACV but buying a new one just to test is $300+ Also really hoping it isn't the ECU on its way out.
*edit. After resetting the ECU and having to keep it from stalling by hold the accelerator in a bit, I managed to get it to idle by itself at 500 RPM. I went for a drive and then let it sit for a couple hours. Tried to start it up later and was having a hard time, it was turning over fine but wouldn't start. It eventually started and revved up to 2300 RPM and started to hunt from 1k to 2k again like it was a couple of weeks ago. I'm really thinking the IACV is bad.
Old 07-17-2010, 05:45 PM   #9
Durandal
Durandal's Avatar
Pulled all my spark plugs today, and they were all soot black so I cleaned them with a wire brush and some brake cleaner (they are iridiums with less then 10k on them).
I tested my intercooler piping with a homemade boost tester and it wasn't leaking.
Took the car for a drive after resetting the ECU. It started up cold at 2500 RPM and slowly came back down to around 1800. While driving I noticed when the clutch is pushed in the revs bounce from 1000 to 2000 continulously. (An ongoing problem that comes and goes that i've been trying to solve)
Come back to the house and right before I shut it down the MIL and CEL come on. I shut it off thinking that I will have a code that will point me in the right direction. Put my paper clip in and turn the key and my CEL light isn't flashing just on solid with my "SLIP Cont off" light flashing. 30 mins later I try to check the codes and the CEL light is flashing steady telling me there is no codes.
I start looking into my electrical system checking the plugs at the ECU which look fine, they are tight and none of the pins are bent. (The car is pretty much stock)
Upon looking at the large bundle of wires that come through the firewall from the ECU I find this.
There four wires (3 black and red stripe one and 1 thicker black one all spliced into one black and red wire and also another 2 wires spliced into 1 where the blue electrical tape is. That's not standard I'm assuming?
I had a greddy emanage ultimate that I used to have hooked up only for the speed limit removal and speedo adjustment for bigger rims. I disconnected it awhile ago trying to eliminate possible problems while troubleshooting but it wasn't the problem. I'm thinking I could hook it back up and use it to datalog some data to troubleshoot with although I've never used that datalogging part of the EMU, hoping its straight forward.
Anyone have any ideas?
After looking at some electrical diagrams, I'm starting to think I have some grounding problems.
Old 07-17-2010, 08:55 PM   #10
pwpanas
Supra Owner
pwpanas's Avatar
No that doesn't look right. That's definitely not an oem splice.
Rough Idle Issue suprajim MKIII Supra 9 12-19-2009 10:35 PM
idle issue MA70-3.0GT MKIII Supra 14 11-17-2009 05:01 PM
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
Blow off valve / idle issue AlpWhitE46 MKIII Supra 9 10-10-2008 11:49 PM
Wastegate Idle issue... please help Subjug4tor MKIII Supra 9 05-15-2008 01:59 AM
