Old 05-24-2010, 08:19 PM   #1
gambit1982
gambit1982 is on a distinguished road
Default Engine harness question between auto and manual
Hi,
I purchased a 2jzgte swap that comes with a manual tranny detached. There is however an auto flywheel that is attached to the engine. And I believe the engine harness must be automatic? The swap did not come with any ECU.
My question is.. is there any difference between an auto and manual engine harness? Will an auto ECU and a manual ECU fit the connector on the engine harness just fine? Will there be any modification required? Please help answer my question. Thank you.
gambit1982 is offline   Reply With Quote
Old 05-25-2010, 03:00 AM   #2
Originally Posted by gambit1982 View Post
Hi,
The plug(s) on the harness that connect to the are the main differences between the manual and the auto harness. The same ecu will fit either harness (those plugs are identical, regardless of whether its a 6spd or auto).
If you want to modify an auto tranny to adapt to a manual transmission, then yes it would have to be modified - due to the differing transmission connectors.
Old 05-25-2010, 03:58 AM   #3
gambit1982
Hi,
Are you saying the connectors on the harness differ between an auto and manual setup in term of sensors?
but then you're saying the connector that connects to the ECU is identical, regardless if it's an automatic or manual engine harness, correct?
So for example if I have an automatic engine (with an automatic engine harness lets say), and if I were to connect a manual ECU it would fit the connector on that harness?
Sorry for asking so many questions. i just need some clarification that's all. Thanx
Old 05-25-2010, 04:22 AM   #4
Hi,
No, the auto ecu actually controlls shifting, so it's not a connector for a sensor, its a connector for a shift controller. On the manual, the connectors are both sensors, I believe.
Yes, the ecu connector is identical.
Yes, the manual ecu would fit fine with the auto harness, but you wouldn't have the appropriate connectors to plug the auto harness into the manual tranny.
Old 05-25-2010, 05:34 AM   #5
gambit1982
Gotcha. Thank you for your help, much appreciated!
convert supraIV from auto to manual question turbofreak128 Non-Generation Specific Questions 0 03-03-2008 10:46 PM
auto wiring harness on manual? mizuboi MKIII Supra 0 02-22-2007 07:15 PM
Engine Harness question kidsusukigsxr Non-Generation Specific Questions 0 01-31-2007 05:33 AM
