Old 05-26-2009, 03:58 PM   #1
TT97
TT97 is on a distinguished road
Default 620rwhp+ on pump gas
Hello i am new on these forums and was wondering what turbo to choose to reach 620rwph+ on pump gas spooling at around 4000rpm? ?? what exhaust is recommended?? Ti??
TT97 is offline   Reply With Quote
Old 05-27-2009, 02:18 AM   #2
Are you willing to supplement with methanol injection and/or nitrous? On pump gas alone, what you're asking for really isn't possible with a 3L 2jz-gte.
Old 05-27-2009, 04:32 PM   #3
TT97
Well, what is the most RWHP i can squeeze out of a t67 turbo with pump gas or methanol injection????
And can u also explain how a methanol injection kit works?? and how its used up and costs for it?? Thank You
Old 05-28-2009, 01:04 AM   #4
With pump gas and methanol injection, you can expect about 600rwhp out of a T67-equipped us-spec 2jz-gte, through a 6spd. This assumes the turbine a/r of your T67 is .80 or bigger.
A meth injection kit sprays methanol into the charge-air piping when you boost, so your (only) 93 octane fuel doesn't lead to detonation at moderate boost levels (eg. 24psi). You'll need a high-end meth injection kit - something made to go on a civic won't cut it.
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
