#1 |
Supra Owner
The 2jz-gte and the 2jz-ge are similar engines, but they are not the same. The non-turbo ('ge') version has higher compression pistons (which is bad for forced induction), a completely different cylinder head, and no oil squirters to cool the pistons. Add that to the fact that the entire abs braking system, transmission, differential, ignition, ecu, suspension, etc., etc. on the non-turbo mkiv is all downgraded. Without a huge investment, it'll never be anywhere near what you'd get if you'd start with a tt in the first place.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 04-27-2009 at 09:28 AM. |
#2 |
What about the single turbo's? How bad are they?
Sorry about all the questions but i don't have 30, 000 for a tt. My friend has an 88 mk3, with a 7m-ge non-turbo, can he put a turbo on it, possibly tt?
![]() they.call.me.curtis
#3 | |
Supra Owner
Any engine can be 'upgraded' to handle forced induction, but it won't measure up to an engine that was specifically designed for it. For example, you can lower the compression a bit by using a thicker headgasket...but that changes the shape of the combustion chamber which negatively affects the engine's performance. In theory, you could take a 2jz-ge, change the pistons, mount oil squirters inside the block, and port the head to better handle the forced induction...but doing all of that properly (including reassembly) would probably cost about $4K or so. Add to that the cost of the single turbo kit, plus installation, the upgrades to the ignition, fuel system, brakes, suspension, transmission, and differential, and you're looking at a LOT more than the $ it would have taken to get a TT in the first place. You may not have the $ for a TT right now, but work hard for a few more months and you'll have the car you know you really want right from the start. Just mho.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#4 | |
#5 | |
Supra Owner
I'm going to pick "option 3" out of the two choices you provided: Just wait and save $ a bit longer, and then get the car you really want. Again, just mho.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 04-29-2009 at 09:42 PM. |
#6 |
Alright thanks for all the help man, i might look around for an 89 single turbo 7m-gte.
That car i was looking at is right hand drive, my mom said i can't get a rhd, im only 17 so im still living at home and going to school.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Quick question | 88ProjectSupra | MKIII Supra | 1 | 04-24-2008 11:56 PM |
| quick question need answered quickly | switchblade | Non-Generation Specific Questions | 5 | 07-21-2007 12:47 AM |
| Quick Question | SUPRA18 | Non-Generation Specific Questions | 1 | 02-15-2007 02:07 AM |
| New here, quick question on possible lean issue | adamsbomb | MKIII Supra | 6 | 02-13-2007 04:42 PM |
| Quick question | AutoXMan | MKIII Supra | 12 | 09-30-2005 06:40 AM |
