Old 10-08-2008, 01:23 PM   #1
theboy641
theboy641 is on a distinguished road
Default 94 n/a supra questions
was changing my alternator belt 2day and found the bottom pully (crank) seemed to be fully foating and i was able to turn the outside of the pully in both directions, i think there is a rubber dampener built into these pulleys but im unsure if it has split and is allowing this to hapen, saying this the belt is still being driven.
Also when accelerating hard there is a knocking noise from the rear such as a worn bush, but when i looked it seems as tho there should be 2 mounts from the subframe to the diff but there is only 1 fited, when looking thru the other hole in the subframe you can see where another bolt should go into the diff, if anyone could help it would be appreciated.
cheers will
theboy641 is offline   Reply With Quote
Old 10-09-2008, 01:10 AM   #2
cheers will
Sorry to say this is one of the few common problems with high mileage mkiv Supras. You'll need a new crank pulley/harmonic balancer.
I'd suggest you call Toyota to get the proper bolt for your diff where it's misssing.
Old 10-09-2008, 07:57 AM   #3
theboy641
cheers mate do you have any idea how much 1 is and you do think there is a mount missing for the diff.
Old 10-10-2008, 12:01 AM   #4
A bolt from Toyota won't be more than a few bucks or so. Can you post a pic of the area with the missing bolt?
Old 10-10-2008, 07:39 AM   #5
theboy641
have just found out that the turbo models have 2 mounts and non turbo models only have the 1. also have found a standard bottom pulley for ?110+vat and delivery.
also was out lastnite and some w**ker managed to hit my car wen driving past, has left 2 marks down side of car and cracked the mirror plastics, gr8 huh
Old 10-11-2008, 08:04 PM   #6
Good news on the mounts and the pulley, but really sorry to hear about the w**ker.
Old 12-20-2008, 03:12 AM   #7
drewtiss
drewtiss is on a distinguished road
There's going to be no problem in my case. I am really planning to change my crank pulley since last month. Maybe it's time to purchase one now.
drewtiss is offline   Reply With Quote
Some questions about my 1988 Supra... Somajunkie Non-Generation Specific Questions 11 06-18-2007 05:47 AM
