Old 07-12-2005, 04:06 AM   #1
Edin
Guest
Posts: n/a
I've read some stuff about the NA and TT Supras and it seems that the TT version is a lot better suited for aftermarket modification. I'm looking to buy one next year and I would like to know what some of you think. I would probably like to make somewhere around 500 whp and some sites have suggested that the NA's setup may not be sufficient for this kind of power. Right now I'm thinking that the TT is better because it was made to handle the extra power and the NA would need more mods, in order to get the hosepower up and still keep it reliable.
Old 07-13-2005, 10:33 AM   #2
the_fallen
the_fallen is on a distinguished road
just a side note, the 2jz-ge makes almost the same power as a 7m-gte
the_fallen is offline   Reply With Quote
Old 07-13-2005, 11:53 PM   #3
Supra Choice
Guest
Posts: n/a
I'm assuming that the 7m-gte is older and single turbo. I've looked up some things and I think that the 97 Supra is probably what I want. I think that with a set of new turbos, complete exhaust, and other small upgrades the car should be able to put up a good number. Not that it doesn't do that already.
Old 07-31-2005, 01:05 AM   #4
SupraMKIV2jz-GTE
SupraMKIV2jz-GTE is on a distinguished road
Supra TT are way better for aftermarket mods. 500hp is very achievable with a twin turbo. The BPU setup offered by suprastore.com is good for 400+rwhp@18psi. BPU means that you have a boost controller, catback exhaust, downpipe, and a boost cut controller. With the addition of cams and cam gears you could be looking at close to 450rwhp. A stage1 turbo upgrade can get you well into the 500s for not alot of money. Even with 500+rwhp the car would still be extremely reliable and streetable. If you are going to up the hp I recommend getting a 6speed so that you dont have to build up the auto tranny, the 6speeds are more exspensive, but soo much more fun
SupraMKIV2jz-GTE is offline   Reply With Quote
Old 07-31-2005, 05:12 AM   #5
SupraMan1784
the tt has better internals...u could crank up the boost waaay past stock without changing them...saving you some money and time...greatest engine ever produced haha
Now: Saving for an MKIV
Broken Rides:
Old 07-31-2005, 06:29 AM   #6
Poodles
Yeah, the turbos are able to produce enough PSI to get some good numbers, just upping the boost on them is enough to add a lot of power, but allowing the engine to breath better allows the turbos to spool up faster. To get the amount of power out of the N/A....well, there is only one way to increase power, burn more fuel, which means more air. Nitrous, forced induction (turbo, supercharger), or extra displacement are the only ways, and I don't think you're going to be able to bore out the engine large enough to get that much power
Save the trouble, get the turbo.
Old 07-31-2005, 07:20 PM   #7
SupraMan1784
tru that
Broken Rides:
Old 08-02-2005, 08:13 PM   #8
daiagaru2
daiagaru2 is on a distinguished road
2jz-gte=stongest engine,most durrable,most reliable,most upgradable
daiagaru2 is offline   Reply With Quote
