Old 09-18-2007, 02:01 AM   #1
west_side_supra
west_side_supra's Avatar
Default the rebuild starts
the block is now surfaced, been pressure tested, and bored .20 over
so far the parts recived are
.20 stock pistons/wrist pins/clips/seals
Eagle rods
full gasket kit
Greddy timing belt
Timing belt tensioner
EGR block off plates
Hose techniques hose kit
Parts still waiting on are
ARP head studs/nuts
ARP main studs
HKS HG <not stopper :,~(
TRD oil filter
valve cover studs
sheet metal < to weld over that damn EGR cooler plug
NGK irradium XI
NGK 7.5mm wires
toda valve springs and retainers
brian crower valves
cams / webb racing cams
full bearing kit
uhhh well there is probably more but thats all i could think of off the top of my head
PICTURES
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 09-18-2007, 06:59 PM   #2
supramacist
supramacist's Avatar
Just curious as to why you chose a greddy timing belt over the toyota brand?
The toyo oem replacement is under 55 bucks.
Old 09-19-2007, 12:41 AM   #3
west_side_supra
because, its blue and says greddy :P why does everyone else choose the greddy belt over the OEM, i was guessing cause the greddy may be stronger and can probably can handle more HP than the OEM before it snaps or slips, neither is good. and did i mention its blue and says greddy
fidenza cam gears
Old 09-20-2007, 05:03 AM   #4
tone loc
tone loc's Avatar
i got a greddy belt too. its nice
Old 09-20-2007, 05:06 AM   #5
west_side_supra
but was i about right on why people choose the greddy belt?
and you know anything on the install of the EGR block off plates? and EGR removal
fidenza cam gears
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
To rebuild or not to rebuild that is the question 88supraturbo5speed Non-Generation Specific Questions 6 04-21-2008 04:05 PM
PLEASE help newbee with engine rebuild canadian mole MKIII Supra 4 06-17-2007 01:01 AM
1988 supra engine rebuild 1988Suprakid MKIII Supra 5 06-07-2006 09:07 PM
