Old 09-04-2007, 02:20 AM   #1
night-rider
night-rider is on a distinguished road
Default lex 550s boggin out near 3000 rpms?
got the lex and 550s and ive been playin with ignition timing a bit and fuel pressure but no matter what i do it seems to bog out around 3000 rpms sometimes a bit sooner its alright at idel when i rev it sumtimes makes a noise but not much its in all gears and my air fuel gauge flicks to lean when it happens
1987 turbo full 3" exhaust, k&n fipk, manual boost controller, walbro 255lph fuel pump, aeromotive afpr, 550cc injectors, lexus afm, fal dual electric fans, fluidyne rad, 3 angle vale job, adjustable cam gears
night-rider is offline   Reply With Quote
Old 09-04-2007, 04:51 AM   #2
abhattan
abhattan's Avatar
did you do an upgraded fuel pump? How much boost are you running?
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Old 09-04-2007, 02:59 PM   #3
night-rider
yes i ave a walbro fuel pump and aeromotive adjustable fuel pressure regulator and before i installed these new parts i was running 11 pounds but now i havent been able to get past 8 it starts boggin out
Old 09-04-2007, 05:11 PM   #4
abhattan
abhattan's Avatar
How are you controlling your boost? Boost controller or shimmed wastegate? If you slowly accelerate will it run smoothly past 3000 rpms?
Old 09-04-2007, 06:23 PM   #5
night-rider
i hbave a greddy manual boost controller set at thbe minimum setting it seems like if i accelerate slowly i can go past 3000 ive only taken it to ahbout 3500 cause i didnt want to pushb it also i put in iridium spark plugs could thbat make a difference perhbaps whben i get boost it blows out thbe spark? i thbink factory is platinum tipped?
Old 09-04-2007, 08:37 PM   #6
supramacist
supramacist's Avatar
Ya the stock plugs were NGK platinums.
I don't think the iridium tips are going to cause you to bog.
The solution to that is a blaster coil.
Have you checked your fuel pressure regulator?
Old 09-04-2007, 09:43 PM   #7
night-rider
i hbave installed a aeromotive adjustable fel pressure regulator and i ave tried different pressures and it seems to only affect it slightly my supra manual says at idle with vacuum hose connected pressure sould be 23-30 pounds i hbave hbeard from some people hbat with thbe 550 injectors you should decrease fuel pressure?
Old 09-04-2007, 11:34 PM   #8
abhattan
abhattan's Avatar
If your running around 11lbs, you should up the fuel pressure to about 34 psi. For every lb of boost, a lb of fuel pressure. 3000 is right where you should be at full boost and if you are leaning out because of fuel pressure, that would probably make it bog. But I couldn't see it doing it that much. Check it any way. Did you check all of your piping and vacuum lines?
Old 09-05-2007, 04:29 PM   #9
night-rider
i ave chbecked all my vacuum lines and thbey are all good and my pressure regulaer hbas a vacuum line to it and it automatically increases fuel pressure pound for every pound of boost , anothber thbing ive noticed it will do it at an idle it is hbarder to nitice but i can feel it hbere and thbere and it flickers to lean whben it hbappens , occasionally it will drop thbe idle down to about 500 and it will constantly show lean then ill rev it up and it will be normal again
Old 09-05-2007, 10:38 PM   #10
abhattan
abhattan's Avatar
It's kind of hard to say without me actually listening to it and experiencing it myself. If your timing is good, I would also check the cam positioning sensor or the crank sensor. Were the injectors used? If so, did you have them benched flowed?
Please help...93 N/A high RPMs uberbg MKIV Supra 5 11-12-2007 04:04 AM
wont go past 3000 rpms mk3ben.com MKIII Supra 6 09-22-2007 07:52 PM
1986.5 Idling at high RPMS Sasukevh MKIII Supra 2 06-14-2007 04:56 AM
Engine seems powerless until higher RPMs Ahmad88 Non-Generation Specific Questions 8 06-22-2006 01:58 PM
Sputter @ high rpms with pedal all down! MKIIISupraTurbo Non-Generation Specific Questions 2 11-11-2005 01:47 AM
