Old 09-03-2007, 09:59 PM   #1
MAG.net
MAG.net is on a distinguished road
Default need help with 7mgte idle problem
hi, ok so i have this idle problem, it fulxuates up and down with no gas applied. i was told by a friend that it could be a vaccum leak and another told me to check the iac. anybody else have an idea or had the same problem? pls help. thanks in advanced
MAG.net is offline   Reply With Quote
Old 09-03-2007, 10:05 PM   #2
supramacist
supramacist's Avatar
Vaccume leak is the first thing to check.
That's what it sounds like.
After that I'm thinking timing. It's hard to say without more detail.
Old 09-04-2007, 01:07 AM   #3
carfanatic89
carfanatic89's Avatar
I think a vacuum leak
Old 09-04-2007, 01:14 AM   #4
MAG.net
thanks man
Old 09-06-2007, 06:10 AM   #5
It really could be either the ISC (Idle Speed Controller) or a vacuum leak.... another possibility is the TPS IDL switch not closing properly.
To test for a vacuum you've got a couple options. What's probably the simplest is to grab a small propane torch, open the valve a little, but don't light it. Then you trace each of the vacuum lines with the torch. If you pass a leak you'll know it, the idle will shift a fair amount.
The TSRM has details on testing and calibrating the TPS (which is the second thing I'd try): http://www.cygnusx1.net/Supra/Librar...ction=FI&P=100
Then, I'd try testing the ISC per the TSRM and if it tests out fine, disassemble it completely (take your time and be careful with the parts) and clean it out thoroughly.
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=106
Idle problem tokis MKIII Supra 2 06-29-2008 01:00 AM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
Idle Problem. Please Help panicos MKIV Supra 18 01-01-2006 06:56 PM
