Old 09-06-2007, 01:17 AM   #11
Supra2NR
Supra2NR's Avatar
Originally Posted by supramacist
Do you mean a valve??
it could be a lifter,
does it sound like a loud clock ticking sound
or a have you heard a horse with the shoe tapping in the pavement, only in a really really high rate of speed thats what my rod knock sounded like b4
Old 09-06-2007, 01:19 AM   #12
Supra2NR
Supra2NR's Avatar
what does it sound like
does it sound like a loud clock ticking sound?
thats what it sounded like when my friend had problems with his lifters
now, my rod knock on my NA sounded like a horse with horseshoe tapping the pavement or cement,
only in a really really really high rate of speed
Old 09-06-2007, 02:28 AM   #13
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Cool
If the sound is low pitched and slow, it is a rod knock. It will go away as the rpm's increase. If it is higher pitched (not too high) sound, then it is valve noise. The rod noise will also be a little slower than a valve noise because the bottom end of the motor moves slower than the top end. If it is in between and sounds more like a rattle, then it probably is the wrist pin. This also goes away to a degree with incresed RPM's. However, you will hear it most upon acceleration and deceleration. I believe it is either a rod knock or a wrist pin knock. These are the things that could go wrong in your cenario.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 09-07-2007, 06:43 AM   #14
jon_570
jon_570 is on a distinguished road
^^actually the top end moves half the speed of the bottom end.
jon_570 is offline   Reply With Quote
Old 09-07-2007, 09:13 PM   #15
abhattan
abhattan's Avatar
No, the top half rotates twice the speed. for every complete rotation the crank makes, the cam does that twice.
Old 09-08-2007, 05:26 AM   #16
supramacist
supramacist's Avatar
Think about it like this.
The crank is large in diameter and the cams are smaller in diameter and the crank spins it all so wich is moving faster or with more revolutions per minute?
The top half.
Picture Of Knock Sensor Locations ravenmaster MKIII Supra 10 01-31-2012 03:37 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
Engine knock @ 1700-2300 rstutler MKIII Supra 8 03-07-2008 07:36 PM
Rod Knock kewlcoconut MKIII Supra 20 01-13-2006 08:39 PM
Knock sensor..........ebay. rnoswal MKIII Supra 0 11-06-2005 07:24 PM
