Old 08-29-2007, 04:51 PM   #1
Big-E
Big-E is on a distinguished road
Default US vs. Japanese mkiii
Hey guys im new here, just had some questions about the mkiii.
The US turbo version has a 3.0l turbo with 230 hp
The japanese twin turbo has a 2.5l twin turbo with 320 hp
If you twin turbo the US 3.0l theoretically it should get alot more hp then the twin turboes 2.5l japanese version right?
Also do you guys think it would be better to buy a non-turbo then turbo it so that insuracne is lower, or is it easier to buy the turbo since its already setup with a turbo which means less work?
Thanks
Big-E is offline   Reply With Quote
Old 08-29-2007, 08:19 PM   #2
tone loc
tone loc's Avatar
buying a turbo motor fo show
Old 08-29-2007, 08:31 PM   #3
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
i think the 2.5l twin turbo pulls out 280hp and the mk4 3.0l 2jz-gte pulls out 320hp, i think you got that mixed up
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 08-29-2007, 09:02 PM   #4
Big-E
you're probably right..
Any one have an idea than what kind of hp a 3.0l mkiii twin turbo would put out?
Old 08-29-2007, 10:37 PM   #5
oowee623
oowee623's Avatar
200-800hp look at kwnate he has 700+hp
Old 08-29-2007, 11:37 PM   #6
supraman121
Kwnate's is a heavily modified engine to get his 800 hp, But you can modify the 1jz and get the same amount of power.
The insurance shouldnt be to bad for an older car even if it is turbo, it would be better to buy the turbo instead of an na and then go turbo.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-30-2007, 01:00 AM   #7
supradaddy0803
supradaddy0803's Avatar
Think of all those Mark 4's out there and how many turbo kits there are for them for a sec. Ok now look into a 1JZ all of those kits fit I have already checked into it with Jotech here in Dallas we took the twins off mine and everything is a perfect match. And also there is no twin turbo 3.0 in Japan the motors over there were the same as here for the most part except in the 90's there they got the 1GGTE and the 1JZGTE. The 1GGTE is a 2.0 twin turbo and the 1JZGTE is a 2.5 twin turbo. The 1JZGTE was basically the first 2JZ in a sense because Toyota took the motor changed the stroke and a few other things and wala. Also from what you are asking about how much HP you can get out of a 1JZ the block will handle 700+ without and mods to the inside that is pretty substantial.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-30-2007, 05:01 AM   #8
Big-E
i'm talking about the US version which ws the 3.0liter 7m USA version. the 1jz is 2.5 l. The point i was asking about, was that a twin turboed 7m(3.0l) shoulf have more horsepower than a twin turboes 1jz(2.5l) simply because the 7m is a bigger engine.
Old 08-30-2007, 06:37 AM   #9
oowee623
oowee623's Avatar
bigger isnt always better
Old 08-30-2007, 04:54 PM   #10
OfnaRcR
OfnaRcR is on a distinguished road
Thats not how things work.
OfnaRcR is offline   Reply With Quote
Carbon Fiber Hood MKIII????? Dejvid1785 MKIII Supra 11 04-23-2010 07:19 AM
