Old 08-16-2007, 03:23 PM   #1
supraman121
Here's somthing that might save you some money for a while lol http://store.driftmotion.com/product...uct_id_int=401
its a exhaust manifold that is setup for the ct-26 turbo or the stock one that was on your 7mgt, might not get as much power from it as the twins but like i said it might save you some money.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-16-2007, 04:23 PM   #2
pato
pato is on a distinguished road
but he allready has the twins with the motor. so whats the point ?
except the head fuck of trying to get it all working smoothly
pato is offline   Reply With Quote
Old 08-16-2007, 05:26 PM   #3
supradaddy0803
supradaddy0803's Avatar
Ok the mounts you got if post 89. You will need Downpipe, plugs for under the dash and the hood (there is three under the dash and 1 under the hood, electric fan, Fan controller (so much easier than finding all the stuff you need for the hydro fan), MAP, ignitor box, intercooler, piping for intercooler, intake pipe with filter housing, 2JZ power steering line with the two banjos get it at driftmotion, a really helpful vaccum diagram (I can help you out there), 1/2 inch hose for the heater hoses in the back of motor, better boost gauge, Maybe a tach depends mine stopped working, And KY to squeeze it in it is kind of a tight fit. As for your other questions you dont have to extend the harness drill a hole under your speedo cable and run it in and behind your heater core and the harness is long enough. As for the plugs under the dash you might have to go to the stealership or I think driftmotion makes a adapter pigtail for them. Also you will need a really long cable to go from your fuse box under the hood to the alternator because I am sure you have noticed it is on the other side now. For the Downpipe I would just go buy a HKS 3 inch because you get a y pipe and a down pipe and swap that out when it isnt in the car beleive me heed my warning.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
1jzgte swap noa324 MKIII Supra 4 03-07-2006 07:24 PM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
Motor swap questions truexazn510 MKIII Supra 3 12-04-2005 03:58 AM
