Old 07-17-2007, 10:26 AM   #1
igosaur
igosaur's Avatar
igosaur is on a distinguished road
Default No Coolant
Just a quick question.
Assuming the the engine is cold, how far do you think I could drive with no coolant?
My overheating problem finally came to a head today when, a couple of miles from home, a hose buried deep in the engine bay somewhere decided it couldn't cope any more and promptly dumped the coolant all over the road!!!
igosaur is offline   Reply With Quote
Old 07-17-2007, 11:35 AM   #2
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
10-20 minutes maybe, my fan was stuck on my fan shroud and didnt spin and i drove it on the freeway for about 20 minutes with no problems then right when i got home the needle jumped to red zone
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 07-17-2007, 11:45 AM   #3
igosaur
igosaur's Avatar
Thanks for that
I did actually pluck up the courage and drive it home, luckily with no problems.
Old 07-17-2007, 05:59 PM   #4
88Tsupra
88Tsupra is on a distinguished road
did u replace ur HG yet maybe dats ur car way of telling you its going out
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 07-18-2007, 06:06 AM   #5
igosaur
igosaur's Avatar
I know. I can't stay in denial any more.
I've done everything else so it must be the HG!! Better start saving.
Old 07-18-2007, 09:06 AM   #6
igosaur
igosaur's Avatar
I found the reason why the car had dumped all the coolant on the road.
When I put fresh water into the radiator to see where it was coming out, I found a small stub of a metal pipe at the back of the engine that had been covered with a rubber cap tied on tight with a jubilee clip.
I've now put this cap back on nice and tightly, refilled and since had no problems.
Presumably, if this cap was in the process of coming off it would not have allowed the cooling system to pressurise properly and hence cause overheating.
The real puzzle though is what is that pipe doing there in the first place. It seems to serve no purpose except to give the coolant somewhere else to escape from.
I'm still in denial about the BHG.....
Old 07-17-2007, 06:30 PM   #7
f00g00
With a stuck fan and driving at highway speeds you wouldn't have a problem till you slow down and lose the high airflow but with no coolant you won't last more than a few minutes. Ive tried to milk that situation before thinking I could just make it to work, then in less than 5 minutes the rattling started.....
Old 07-17-2007, 06:57 PM   #8
supramacist
supramacist's Avatar
Mine too. It's heated up on me during the test drive after my build.
But it was because I blew a coolant line, because of a 15 year old stock hose clamp.
Old 07-17-2007, 08:40 PM   #9
IHateHacks
IHateHacks's Avatar
A water cooled engine will overheat in less than 5 minutes with no coolant. No way in hell its lasting 15 minutes.
Old 07-17-2007, 09:15 PM   #10
Kuban
Kuban is on a distinguished road
kudos, operating temp is already too far with no coolant. Dont do it or ur looking serious trouble.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Kuban is offline   Reply With Quote
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
coolant on top of piston sevenmgte MKIII Supra 8 05-02-2008 02:34 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
