Old 07-10-2007, 11:19 AM   #11
Cool
tear apart again ? did you ever remove the main crank pulley ?
Old 07-10-2007, 05:58 PM   #12
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
I did the head gasket 4 months ago
OmeGa is offline   Reply With Quote
Old 07-10-2007, 09:12 PM   #13
Cool
yeah but did you ever loosen the main pulley on the crank ?
it's a MF to tighten and makes crazy noises when the engine is running if loose
Old 07-10-2007, 10:06 PM   #14
OmeGa
OmeGa's Avatar
Would that also cause the car to run like crap, because when I had to gimp it home I couldnt go over 2.5-3k RPM and max of 45mph with absolutly no get up. It felt like I was driving a 5 speed oversized golf cart.
Old 07-11-2007, 01:42 AM   #15
Cool
no just sound like crap
Old 07-17-2007, 01:04 AM   #16
OmeGa
OmeGa's Avatar
Okay so I took it down to the cams and found the the gear that drives the CPS is chipped and messed up and there are shavings in the head by the first valve so I check it and the sound is coming from the first valve.
My question is, is it possible to take the cam out and replace the vavle and everything with out taking the head off. If so, how hard is it?
Old 07-17-2007, 08:37 PM   #17
IHateHacks
IHateHacks's Avatar
Come on now use your brain. Yes the head has to come off to replace a valve, thats the way it comes out, through the combustion side of the head.
idle stuck 84supradude MKII Supra 2 04-08-2009 02:49 AM
1983 Lifter bore Supra83_auto MKII Supra 0 01-05-2008 09:32 PM
Wastegate stuck open mkiiisupra MKIII Supra 6 09-17-2007 02:09 AM
7MGE - Stuck with changing Head Gasket??? pasupra MKIII Supra 8 07-31-2006 10:41 AM
