Old 07-08-2007, 05:22 AM   #1
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
Default Stuck Lifter.. or so i think
Right now when I start my car it makes a rattling/ clanking sound then it has a periodic clank about every second at idle and the higher the rev the faster it goes. It all started because it was really low on oil (I know, I know...stupid me). It also has very low oil pressure (I think it was around 10psi or less at idle and upto 50-60psi at full throttle.) I have had a few people suggest that its a bad lifter but is there an easy way to check if it is.
Also if it is a bad lifter how hard and expensive is it to fix because I will be doing it my self and if it is cheaper to part with the car then I will just sadly go that route.
OmeGa is offline   Reply With Quote
Old 07-08-2007, 08:42 AM   #2
SupraDupra
SupraDupra's Avatar
I can assure you it's not a bad lifter. Our engines just don't have 'em The cam directy interacts with the valves so there is no lifter/pushrod combo in the mix. What you're describing sounds like it might be in that neighborhood though. Given your description I would tend to suspect a stuck valve or related component. Perhaps the valve is returning to the closed position when the piston is on it's compression stroke and the spring hangs up for a second then slaps up against the assembly. With your bad oil pressure you might have gotten a little dry on top and done some damage to the head. Get a second opinion before you get to worried though. It's hard to diagnose from here.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 07-08-2007, 02:33 PM   #3
IHateHacks
IHateHacks's Avatar
Ummm 7M's have lifters. What do you think the shim sits on? A lifter. We have mechanical lifters in our engines, not hydraulic.
You ran it low on oil now it ticks/knocks. While it was low on oil you had major metal to metal contact and now the bearings are worn out of spec.
Old 07-08-2007, 07:52 PM   #4
SupraDupra
SupraDupra's Avatar
Perhaps in the most litteral sence ,the TSRM calls it a lifter ,but I'd just call that a bushing. In any case ,we agree a dry top end lead to premature wear. I got a refurbished head on ebay for $450 that came with everything except camshaft oil seals. With the increased open areas around the moving parts the oil has less restriction and hence lower pressure.
1974 'Cuda - 318
2001 Cherokee
Old 07-08-2007, 08:13 PM   #5
OmeGa
OmeGa's Avatar
So basicly the only way to fix this is to rebuild my head?
Old 07-08-2007, 09:04 PM   #6
SupraDupra
SupraDupra's Avatar
For starters you would want to get it apart and measure everything to see just what state it's in. Keep in mind though ,it will seriously hurt your resale if it's in a million pieces. You have to decide at this point if you want to take the hit selling it cheap with potential head problems or if you want to follow the route of repair and hang onto it. Not a fast ,simple ,or cheap task ahead.
1974 'Cuda - 318
2001 Cherokee
idle stuck 84supradude MKII Supra 2 04-08-2009 02:49 AM
1983 Lifter bore Supra83_auto MKII Supra 0 01-05-2008 09:32 PM
Wastegate stuck open mkiiisupra MKIII Supra 6 09-17-2007 02:09 AM
7MGE - Stuck with changing Head Gasket??? pasupra MKIII Supra 8 07-31-2006 10:41 AM
