Old 05-23-2005, 02:30 AM   #1
wikdMK3
wikdMK3 is on a distinguished road
i recently bought a MKIII supra n/a, 89 to be exact. i want to get an electric fan setup but im not sure which one to get. fluydine has one, its one big 14in fan setup that i found for about 130. then i also found the flex-a-lite setup which is dual setup but not sure on the sizes of the fans, and is about 360. trying to get some imput on which one to buy based on quality and performance
wikdMK3 is offline   Reply With Quote
Old 05-23-2005, 03:47 AM   #2
monkihead
monkihead's Avatar
360 is a bit much for the flexalite. did you try summit racing? they carry the same one wholesale. if your getting the dual electric it may be the slim design. its wicked thin!
monique- better off dead
Old 05-23-2005, 09:01 AM   #3
just make sure the fans you get flow between 2500-3000cfm, our engines need this much air thrown at it
if you get any less you will find it overheats
i've heard good things about both companies... just go for whichever one you feel
Old 06-03-2005, 04:07 AM   #4
I run a 14" Hayden 'S' blade, 1100 cfm, along with the 2 original 6" fans that run when A/C is on. I live in the Mojave desert in Calif. I always run below half way on the gage.
If I were to need another fan, I would use one of these .... $80......http://www.jegs.com/cgi-bin/ncommerc...enbr=361....it pulls 1800cfm for the same amperage draw.
Old 06-09-2005, 02:56 PM   #5
i am using a permacool 16" about 100.00 ( i think might b 14")
behind a fluidyne radiator the cfm is the most important concern .
tein flex or fuel system west_side_supra MKIII Supra 8 04-22-2007 11:01 PM
Targa Flex? ethan12510 MKIII Supra 5 03-06-2007 05:00 AM
coilovers Tein Flex vs RA's Spudboy Road Racing & Autocross 0 05-18-2006 02:39 PM
