Old 05-22-2005, 04:56 PM   #1
hamburgler
hamburgler is on a distinguished road
hey there, my friend and i are trying to instal a manual boost contoller (ball and spring) so that he will boost more. i thought i would register really quickly on this forum so ask a few questions.
1. according to the gauge we hooked up last night stock boost is 6psi? is this right?
2. what is a safe amount of boost we can run? i was thinking 10psi. his car is completley stock
3. will i need to disable the boost selenoid? is there even one. there was one on my old mazda that i had to unhook. i know absolutly nothing about supras, but have a fair bit of knowledge when it comes to FI.
4. is there a guide to hook up this contoller because i have the boost controller set at 10psi from my old mazda and its still only boosting 6. thanks
hamburgler is offline   Reply With Quote
Old 06-09-2005, 03:47 PM   #2
replying to this post may be too late
however i want to warn you:
appling more boost without planning will result in a blown head gasket before you know it . and btw a manual controller is fun at first but you'll find boost levels ranging all over the place
using a stock boost gauge is not a good idea it only goes up to like 8 doesn't it ? once you start getting fuel cut off you might want to back off a little . atleast until you have an accurate measurement of boost
Old 07-08-2005, 08:19 PM   #3
hamburgler
thanks for the reply. so what is the stock boost set at? isnt it safe to boost 10 from the 7 stock if it is 7? i need some instructions on what to disable because no matter what i do its still only boosting 6-7psi
Old 07-09-2005, 12:00 AM   #4
monkihead
monkihead's Avatar
6-7 is stock 11 is the safety point. fuel cuts at 12 and turbo runs out o' power at 14. i put a ball and spring in mine and she started to act strange.
monique- better off dead
Old 07-13-2005, 12:55 PM   #5
sometimes you may have to turn up the boost controller a little more than usual... they differ on different cars
what sort of boost controller are you using?
manual boost controller tak2099 MKIII Supra 5 11-23-2009 11:47 PM
Manual Boost Controller and Turbo timmer question ethan12510 MKIII Supra 5 02-20-2008 10:54 PM
manual boost controller!!!!!!! justin1642 MKIII Supra 6 01-16-2007 10:01 PM
