Old 06-24-2007, 11:03 PM   #1
suprabahamut
Default stupied question on head removal
I have got all the right tools now the hex sockets and got most of the parts off the engine like the cam shafts, valve covers, exhast manifold, and other parts. All I need is the intake mainifold off, the bolts are jamed on there and some of them have been rounded off. so my stupied question is can you just loosen the head bolts and take them all out, to where the head is ready to come off and pull the head with the intake mainifold off togheter and work on the manifold where I have more room and can get some chananal locks on the rounded off bolts is this possible
Old 06-24-2007, 11:19 PM   #2
plaaya69
plaaya69's Avatar
Cool
You should have enough room to get to that screw but since their it two parts to the intake manifold you first need to remove the one where the throttle body sits on and the isc sits on. Once you get that then remove the lower intake manifold and it would make it very easy to get to.
Also you did not need to remove the camshafts you just needed to rotate them maybe once or twice to get to the headbolts.
One more tip, when you remove either bolts that are old or rusty dont apply full force just tap it with your palm a few times and that will break it loose and then you will be able to remove the screw or screws and wont have to worrie that much about breaking them.
Hope thie helps and G/L.
Old 06-24-2007, 11:36 PM   #3
supramacist
supramacist's Avatar
Pull the head with the intake on. As long as you remove down to the y pipe you should be good.
The you can figure out how to the get them off a bit easier.
Old 06-26-2007, 02:28 AM   #4
suprabahamut
so it is possible to remove it all together
Old 06-26-2007, 04:18 AM   #5
Yeah you can pull the head with the intake plenum attached. Make sure everything else is out of the way though.
Old 06-27-2007, 02:37 AM   #6
SupraDupra
SupraDupra's Avatar
At your local auto parts store you can get a set of sockets made for stripped heads. Usualy called "easy outs" ,they have a design that bites into the metal (for removal only). I lost a couple bolts myself ,but home depot is great for replacing all your low grade bolts. Good luck!
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 06-27-2007, 03:29 AM   #7
suprabahamut
do places like home depot or lowes carry any grade 8 or 5 bolts
Old 06-27-2007, 03:48 AM   #8
SupraDupra
SupraDupra's Avatar
I'm afraid not. You need to order head bolts and the like from an auto parts supplier. I only use home depot bolts for "low stress" applications.
1974 'Cuda - 318
2001 Cherokee
Old 06-27-2007, 04:02 AM   #9
Home Depot does (or at least used to) carry grade 8 bolts, but not in metric sizes. I have found that most of the smaller chains around here carry or can order them though.
Old 06-27-2007, 04:56 AM   #10
supramacist
Let's get back on topic here.
If you are still on stock head bolts. The least you can do is order toyota oem's.
But you should go ARP and sleep alot easier. You are going to need a torqu wrench. pay attention to your head. Place the washers on the grooves before your studs or bolts. I went with studs. Hard to beat a studded engine if your'e going for a DD big boy toy.
HKS Stopper MHG. You want one.
How is your block? Did you have it machined?
Give us details man. Help us help you.
Head Gasket Question 91na MKIII Supra 11 04-20-2008 12:42 AM
Head Gasket DIY Question rinso MKIII Supra 4 10-18-2007 07:35 AM
Head question! Jermalicious MKIII Supra 5 06-12-2007 04:39 PM
head question Boozer MKIII Supra 4 06-10-2006 04:52 AM
